Home / Technical Articles / Energy and Power / The basics of synchronous machines in power distribution networks
Synchronous machines can be used as generators or motors. They are of 3-phase construction, even though some special exceptions can be found. A bulk of the applications are within power ranges roughly varying from a megawatt level to several tenths (or even hundreds) of megawatts with rated voltages from 3 kV to 15 kV.
The basics of synchronous machines you MUST fully understand
The basics of synchronous machines you MUST fully understand (on photo: ABB Type AMS 900L6L BST 13700kW / 11688kVA Brushless Synchronous Motor/Generator. 12470V, 60Hz, 1200RPM; credit: phxequip.com)
Special designs of the HV synchronous machines have also been introduced whose rated voltages can be of several tenths of kilovolts.
More complicated construction, control and protection demands of synchronous machines resulting higher unit costs limit the use of synchronous machines on lower output power levels.
On the other hand, the excitation control features cater for more flexible means of operating the machine with the optimal reactive power flow according to the network conditions.
Reciprocating compressor motor 24 MW
Figure 1 – Reciprocating compressor motor 24 MW
The armature winding is commonly placed in the stator whose construction is of the three- phase design and quite similar to asynchronous machines. The field winding is placed in the rotor whose design is quite different from the ones in asynchronous machines.
Two different basic designs can be separated, namely round or cylindrical and salient pole. The round or cylindrical designs are used in machines operating on high speed, whereas the salient pole design is used in machines operating on slow or moderate speed.
A typical example of slow-speed applications is a hydro power plant generator, whereas a steam turbine generator would represent an example of high-speed applications.
a) salient pole rotor b) round or cylindrical rotor
Figure 2 – a) salient pole rotor b) round or cylindrical rotor
The rotor is excited through the field winding with a DC power source. In motor applications, the excited rotor rotates according to the speed of the three-phase AC-field in the stator.
In generator use, the prime mover rotates the excited rotor generating an EMF to the stator windings, whose magnitude and frequency correspond to the excitation power in the rotor and the rotating speed of the prime mover.
Under normal operation conditions, the rotating field in the stator and rotating rotor remain in synchronism. Unlike with asynchronous machines, the difference slip between rotor and rotating field speed in stator is an indication of abnormal operation situation and must be dealt with immediately.
The synchronous speed ns [rpm] is given by equation (1) below:
Synchronous speed formulae
The synchronous angular velocity ωs [rad/s] is given by equation (2):
Synchronous angular velocity
Where
  • f is the network frequency [Hz]
  • p is the number of poles in the machine
Some synchronous machines rely on brushes for delivering the DC current to the rotor for excitation. A more modern solution is the so-called brushless design, where the needed power is transferred to the rotor by induction and the rectifying takes place in the rotor itself.
For some applications, like for really low rotating speeds, the solution utilizing permanent magnets in the rotor is suitable.
For generating the power for excitation purposes, PMGs are commonly used. By the way, PMG stands for Permanent Magnet Generator. The PMG works as a pilot generator connected to the main generator’s shaft, supplying the power for the main generator’s excitation.
Synchronous AC generator with PMG excitation
Figure 3 – Synchronous AC generator with PMG excitation
With a single synchronous machine running as generator, the control of the output voltage is carried out by controlling the excitation. Increased excitation current will result in a higher output voltage, and vice versa.
The frequency control of the output voltage is carried out by controlling the running speed of the prime mover.
When the generator is connected in parallel to a strong network, excitation control changes only the reactive power output of the generator. An increase of the excitation current makes the generator produce more inductive reactive power, thus compensating the inductive loads. A decrease in excitation ultimately leads to a situation where the generator starts to absorb inductive reactive power from the network.
This situation is referred to as “underexcitation ” and is not a normal operation mode of the generator.
The increase in prime mover’s torque cannot increase the rotation speed of the generator, since it is electrically coupled to the strong network. Instead, it increases the active power output of the generator. If the prime mover torque is decreased below the level of rotating losses of the generator, the generator starts to work as a motor trying to rotate the prime mover with the synchronous speed.
This situation is referred to as reverse power operation. The reverse power operation is harmful to the generator and also to the prime mover, thus the situation has to be recognized by the protection relays.
The following figure shows an example of synchronous generator’s capabilities and constructional limitations for operation under different conditions. A normal operation is carried out overexcited, injecting reactive and active power to the network.
When a synchronous generator is started, it is speeded up with the prime mover close to the network frequency and the excitation current is applied to reach the nominal terminal voltage.
Synchronous generator capability curve
Figure 4 – Synchronous generator capability curve
After this, the automatic synchronizer takes over the actual network connection procedure. The synchronizer adjusts the excitation current so that the generator’s terminal voltage matches the network voltage. The synchronizer also checks the phasing and adjusts the prime mover speed to match the generator frequency with network frequency.
In fact, the synchronizer adjusts the generator’s frequency to climb towards the network frequency and closes the breaker when the frequencies have met but the generator frequency is still climbing. This is to ensure that the generator starts producing active power right after network connection has taken place, otherwise the reverse power protection relays would disconnect the generator from the network.
The construction of a synchronous generator and motor are basically identical, except regarding the external connections. The synchronous motor is not synchronized against the network in similar ways as with the synchronous generators.
The simplest way to connect a synchronous motor to the network is the so-called Direct On-Line (DOL) starting, where the motor is started as an induction motor. The motor is “pulled” into the network with approximately 5% slip. Figure 5 describes other starting methods too.
The selection of the starting method depends on several criteria, like:
  • Required load torque during starting sequence
  • Voltage drop in the supplying network during starting
  • Permitted starting time (thermal stress to rotor)
  • Number of starts in a time period
Different starting methods for a synchronous motor
Figure 5 – Different starting methods for a synchronous motor
The capability to control the reactive power output of a synchronous machine becomes a handy feature also in motor applications. By controlling the excitation of the synchronous motor, it is possible to compensate the variable reactive power needs in an industrial plant, thus minimizing the need of additional compensation devices.
Special application of a synchronous motor is a setup where the motor does not supply any active power from its drive shaft, but it is used only to inject reactive power into the network. This kind of synchronous machine is called synchronous condenser.
Today, the synchronous condensers are replaced with SVC devices:
  • Brushless synchronous machines
  • Excitation / reactive power / voltage control
  • Prime mover / active power / frequency control
  • Permanent magnet motors (generators)
Synchronous generator excitation
Synchronisation of generators to a busbar
Reference // Distribution Automation Handbook by ABB
  1. RAJAN
    Apr 13, 2017
    VERY GOOD !
  2. Mohammad Ali dadjoo
    Mar 07, 2017
    The subjects which has delivered are too classic and can be found in books or … .l prefer to know some practical issues.The problems that take place in power plants.
    Your sincerely.
