Home / Technical Articles / What’s common for Beer Mug and Power Factor?
What's common for Beer Mug and Power Factor?
Understanding power factor is not that hard. We have some very common example from the real life you will understand for sure, but first let’s start with some introduction of power factor.
To understand power factor, we’ll first start with the definition of some basic terms:
kW is Working Power (also called Actual Power or Active Power or Real Power). It is the power that actually powers the equipment and performs useful work.
kVAR is Reactive Power. It is the power that magnetic equipment (transformer, motor, relay etc.) needs to produce the magnetizing flux.
kVA is Apparent Power. It is the “vectorial summation” of KVAR and KW.
Example From the Real Life ;)
Power factor - Example from real life
Ok, these folks must’ve been running some heavy reactive power compensation – ’cause there’s no foam P.F.=1 ;)
Let’s look at a simple analogy in order to better understand these terms….
Let’s say it’s friday evening, and you are with your friends at your favorite pub after really hot day. You order up a big mug of your favorite beer for you and for your friends. The thirst-quenching portion of your beer is represented by KW (the big pic on top).
Unfortunately, life isn’t perfect. Along with your ale comes a little bit of foam. (And let’s face it…that foam just doesn’t quench your thirst.) This foam is represented by KVAR.
The total contents of your mug, KVA, is this summation of KW (the beer) and KVAR (the foam).
So, now that we understand some basic terms, we are ready to learn about power factor:
Power Factor (P.F.) is the ratio of Working Power to Apparent Power.
Power factor formula
Looking at our beer mug analogy above, power factor would be the ratio of beer (KW) to beer plus foam (KVA).
Power factor formula - Analogy with beer mug
Thus, for a given KVA:
  1. The more foam you have (the higher the percentage of KVAR), the lower your ratio of KW (beer) to KVA (beer plus foam). Thus, the lower your power factor.
  2. The less foam you have (the lower the percentage of KVAR), the higher your ratio of KW (beer) to KVA (beer plus foam). In fact, as your foam (or KVAR) approaches zero, your power factor approaches 1.0.
Our beer mug analogy is a bit simplistic. In reality, when we calculate KVA, we must determine the “vectorial summation” of KVAR and KW. Therefore, we must go one step further and look at the angle between these vectors.
Power Triangle
The “Power Triangle” illustrates this relationship between KW, KVA, KVAR,  and Power Factor:
Power Triangle
Note that in an ideal world looking at the beer mug analogy:
  1. KVAR would be very small (foam would be approaching zero)
  2. KW and KVA would be almost equal (more beer; less foam)
There are dosen of tools and technical articles/guides published at EEP that can help you to understand power factor and its controlling. Hope these can help:
Resource: powerstudies.com
39 Comments
  1. Jessica Ortiz
    Mar 27, 2023
    I’m trying to use the power triangle to “do some beer math” but I am not getting the same answer. Using “beer math” (If KVA =300 Kw = 270 & PF= .9) my Kvar should be 30kw. Using the power triangle however, Kvar = √(300²-270²) which happens to equal 130.7 kvar. So I’m wondering what I’m missing because Kvar in beer math =30 but using the power triangle Kvar = 130. Help please, examples on this page would be helpful to explain finding a solution for Kvar/Kw/Kva would make understanding much easier. Thank you!
  2. Amar Nath Mishra
    Aug 25, 2022
    Beer glass analogy will impart wrong concept among the students as real power is vector sum of active power and reactive power but, beer glass analogy suggests real power as algebraic sum of active power and reactive power.Requesting to delete beer glass analogy to describe the power factor.
  3. Nazar Ahamed.j
    May 21, 2022
    We have 2000KVAR shunt capacitor
    We need to convert KW kindly workout formula and share me to given mail ID
    33KV supply
    HT current 75Amps
  4. Stanley Osao
    Jun 25, 2021
    Thank you for the simplest explanation and beer analogy to help me understand P.F. As a non electrical engineer, this is a very handy information.
  5. Fernando
    Jun 12, 2018
    Thanks for the simple and easy explanation by the author and by the corrections by readers.
  6. Olga Neiman
    Mar 13, 2018
    Man, there is a Mistake. PF with the sin is kw/kva=cos(Θ)=sin(90°-Θ)
    • Alun Williams
      Mar 18, 2018
      The p.f. shown here with sin is indeed correct. SinΘ = perp/hyp = KVAR/KVA
  7. Server Room UPS
    Mar 10, 2018
    What a great way to describe and explain the power factor. I like this style of learning.
  8. WALTER MARTINS DA JUNIOR
    Dec 20, 2017
    The correct unit for reactive power is kvar, not kVAr.
    • Raman
      Jan 25, 2020
      No, actually its kVAr not kvar
  9. Engr.I.F.Ogbuty
    Oct 29, 2016
    Well said,good job
  10. Ramakrishna
    Feb 17, 2016
    Very clear answer . Thank you
  11. Dinu Alex
    Dec 21, 2015
    good
  12. Stuart
    Sep 04, 2015
    Instructions unclear. Beer now empty.
  13. Robin Koffler
    Aug 17, 2015
    It is amazing how this how often this graphic turns up when you need to discuss reactive power and explain how it can affect electricity bills. With the ESOS deadline on the horizon it is even more relevant.
  14. Jason Koffler
    Apr 25, 2015
    been using this way to explain kva and real power since the mid 90’s.
  15. Alex Damaso
    Apr 16, 2015
    I would like to ask what is the appropriate KW rating of a generator set to used for 5 tonner aircondioning unit? Thanks
  16. Jagdish Aggarwal
    Apr 16, 2015
    this is so simple and interesting. examples are just from day to day life.
  17. Denis mchau
    Apr 15, 2015
    Am student and iwant to know the way of achive my goal to be a engineer .
  18. nick
    Apr 14, 2015
    VERY EDUCATIVE
  19. jorge mosquera
    Apr 14, 2015
    Excelente analogía. Interesante el portal
  20. Saravanan
    Apr 14, 2015
    I didn’t see like this example wow its very help full
  21. ezhil
    Jan 29, 2015
    Analogy of Kirchoffs law
  22. sontakke
    Jan 04, 2015
    Dear Sir,Greetings.
    Its a really interesting Practical Example.
    Congrants for \an \idea.
    • Lui
      Jan 29, 2015
      Greatest description ever! ;) Thanks..
  23. PETER
    Dec 29, 2014
    Very good example
  24. Vidyadhar Joshi
    Dec 11, 2014
    Good Illustration. Hope people donot forget after having a beer. Cheers
  25. Romona Davidson
    Sep 15, 2014
    merci d’un million de… Really appreciate this example……..
  26. Dejan
    Jun 22, 2014
    Jelen Beer FTW.
    Srsly guys, you could’ve picked some less catastrophic Serbian beer :D
    • perendev
      Jun 23, 2014
      Palindrome: Jelenovi pivo nelej.
  27. Gaudencio Toto
    Mar 10, 2014
    Excellent example, served me to explain the power factor to my clients.
    We need more examples applicable to real life. Thanks
  28. Barbara Kerr
    Feb 12, 2014
    Is it correct to say that the equipment itself ‘eats’ a bit of the electricity that can be generated? So there is always a bit of loss in the generation process, lost to the equipment itself? Thanks much for this helpful article!
  29. Loh Kon Min
    Feb 03, 2014
    Great job….I love your power factor analogy using beer as an example!!!
  30. lenin pugal
    Feb 02, 2014
    i need more very common example from the real life like this.
  31. MANI NV
    Dec 27, 2012
    Good approach to teach a topic in a simple way.
  32. SKuchle
    Nov 19, 2012
    Great article I will never be able to look at me beers the same way again.
  33. elbf2801
    Nov 15, 2012
    Took into this extent, the PUB is the Substation and the Brewerei is the Power Plant.
  34. PowertothePeople
    Nov 15, 2012
    Good article. Easy to read and great analogy. However, the equation P.F. = KW/(KW + KVAR) needs to be corrected to P.F. = KW/(KW^2 + KVAR^2)^(1/2) since KVA=(KW^2 + KVAR^2)^(1/2). I understand how the author wanted to keep it simple by associating his beer equation (P.F.= Beer/(Beer + Foam) ) with the actual power factor equation, but this is misleading and will lead to errors. People who aren’t comfortable with this topic will use P.F. = KW/(KW + KVAR) and will not obtain a correct answer.
  35. laxmi
    Nov 15, 2012
    cool…. yesterday only i was questioned on this by laboratory viva examiner!! wish i read this before….
