Home / Technical Articles / Can I Go Off-Grid With Hybrid Systems?
Estimated Study Time: 3 minutes
Hybrid Power Systems
Hybrid wind energy systems can provide reliable off-grid power for homes, farms or even entire communities (a co-housing project, for example) that are far from the nearest utility lines. According to many renewable energy experts, a “hybrid” system that combines wind and photovoltaic (PV) technologies offers several advantages over either single system.
In much of the United States, wind speeds are low in the summer when the sun shines brightest and longest. The wind is strong in the winter when there is less sunlight available. Because the peak operating times for wind and PV occur at different times of the day and year, hybrid systems are more likely to produce power when you need it.
For the times when neither the wind nor the PV modules are producing, most hybrid systems provide power through batteries and/or an engine-generator powered by conventional fuels such as diesel. If the batteries run low, the engine-generator can provide power and recharge the batteries. Adding an engine-generator makes the system more complex, but modern electronic controllers can operate these systems automatically.
An engine-generator can also reduce the size of the other components needed for the system.
Hybrid Power Systems - Combine multiple sources to deliver non-intermittent electric power
Keep in mind that the storage capacity must be large enough to supply electrical needs during non-charging periods. Battery banks are typically sized to supply the electric load for one to three days.
An off-grid hybrid system may be practical for you if:
  • You live in an area with average annual wind speed of at least 9 mph (4.0 m/s).
  • A grid connection is not available or can only be made through an expensive extension. The cost of running a power line to a remote site to connect with the utility grid can be prohibitive, ranging from $15,000 to more than $50,000 per mile, depending on terrain.
  • You would like to gain energy independence from the utility.
  • You would like to generate clean power.
SOURCE: Small Wind Electric Systems – U.S. Department of Energy
  1. Vafo
    Aug 22, 2020
    Hello I have some questions
  2. Edvard
    May 04, 2011
    This should be the future solution for energy generation. It’s not free as it is advertised, but it’s a qute good point for green living and some day we will lough loudly remembering the fossil fuels, nuclear plants…
    We all know this is the future, we cannot slow it down any more… It’s coming…
