Home / Technical Articles / Definitions of Abnormal Voltage Conditions
Estimated Study Time: 3 minutes
Definitions of Abnormal Voltage Conditions (Sag, Swell, Surge and Interruption)
Sag
A sag is a temporary reduction in the normal AC voltage.
A momentary sag is a variation, which lasts for a period of 0.5 cycle to about 2 s usually the result of a short circuit somewhere in the power system. Instances of longer duration of low voltage are called sustained sags (see Figure 1).
Sag - momentary and sustained
Figure 1 – Sag – momentary and sustained
Swell
Swell is the opposite of sag and refers to the increase of power frequency voltage. A momentary swell lasts from 0.5 cycles to 2 s. A sustained swell lasts for longer periods (see Figure 2).
Swell - momentary and sustained
Figure 2 – Swell – momentary and sustained
Surge
Surge is a sub-cycle disturbance lasting for a duration of less than half a cycle and mostly less than a millisecond. The earlier terminology was transient or spikes.
The decay is usually oscillatory. Surges generally occur due to atmospheric disturbances such as lightning or due to switching of large transformers, inductors or capacitors (see Figures 3a and b for examples).
Surge voltage with oscillatory decay
Figure 3a – Surge voltage with oscillatory decay
Surge caused by lightning
Figure 3b – Surge caused by lightning
Interruption
Interruption means the complete loss of voltage. A momentary interruption lasts from half-cycle period to less than 2 s. Longer interruptions are called sustained interruption.
Momentary interruption is usually the result of a line outage with the supply being restored automatically from another source or by auto-reclosing operation. Refer Figure 4 for illustration. An interruption can be instantaneous or of slowly decaying type.
Examples of supply interruption
Figure 4 – Examples of supply interruption
In Figure 4, the one at the top shows the RMS voltage value during a momentary interruption. The figure on the lower left depicts the waveform of a sustained interruption where the voltage drops to zero almost instantaneously.
The waveform on the lower right shows an interruption where the voltage decays slowly.
Resource: Grounding-Bonding-Shielding-and-Surge-Protection – G. Vijayaraghavan, B.Eng (Hons) Consulting Engineer, Chennai, India
  1. chandra shekhar
    Aug 18, 2017
    I am very thankful to you.Please send me all information about power quality
  2. FELIX Jr.
    Feb 01, 2015
    DATE: 01-FEB-2015
    THIS IS A GOOD ARTICLE ABOUT DIFFERENT VOLTAGE ABNORMALITIES IN THE ELECTRICAL POWER SYSTEM OPERATIONS WHICH ARE CAUSED BY DISTURBANCES IN THE SYSTEM BY EITHER THE LOADS OR SWITCHING OPERATION. HOWEVER, EFFECTS OF FROM VACUUM CIRCUIT BREAKER OR CONTACTORS OR SF6 CKT. BREAKER SWITCHING OPERATIONS SHOULD ALSO BEEN EMPHASIZED ON IMPACT TO THE VOLTAGE PROFILES AT THE SOURCE BUS AND AT LOAD SIDE ENDS WITH RESPECT TO SURGE EVENTS.
    THANK YOU.
