Guide to motion control drives
Introduction
This guide aims to give users an overview of high performance drives and motion control. Although written in a simple style to make it relevant to most applications, readers need to have a basic understanding of AC drive technology to benefi t from this guide.
When considering a motion control application it is important to consider all elements in the system including drives, motors, mechanical power transmission components, software, etc. A high performance system has one or more of the following characteristics:
  • high dynamic performance
  • high accuracy reference following and repeatability
  • high accuracy motion functions
  • capability to run different motor types
Motion control versus speed control
Standard variable speed drives normally control the motor by giving a speed command. The system typically has no feedback and speed reference is preset speeds, 0 to 10 Volts, 4-20 mA, or fieldbus. With motion control, there is always feedback of the real position. This is compared to the reference value and the difference is corrected continuously by the motion controller’s profile generator.
Positioning is a good example that highlights this difference. If a standard drive is used for positioning, the motor normally runs at high speed, then decelerates to a lower speed and stops. Alternatively, the drive can follow an analog signal. Either way, no reference profi le is followed, compared for errors or corrected.
This results in low accuracy. Accuracy can be improved if the controller is a high performance motion controller but in this case, the dynamics and the sample time (generally several milliseconds) of the standard drive become limiting factors.
Title:ABB DRIVES – Guide to motion control drives
Pages:64
Download:Please login first
Don't miss anything!
Powered by MailChimp
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Is There Enough Wind on My Site?
Does the wind blow hard and consistently enough at my site to make a small wind turbine system economically worthwhile?...
Solar Energy Expands, Escapes the Power Grid
Solar power has come a long way since its origins as a niche technology for satellites, finding its way into...
Siemens Basics Of Energy
Energy and Automation: Introduction, Motors & Control Siemens A.G. is Europe’s largest electrical and electronics company, producing over 50,000 products...
Close
