Polyphase Or Single-Phase Motor?
A power system can be either single-phase or polyphase. Figure 1 illustrates single-phase power, which is most commonly found in homes, rural areas and in small commercial establishments.
A polyphase power system consists of 2 or more alternating currents of equal frequency and amplitude but offset from each other by a phase angle. Figure 2 illustrates a three-phase power system having phases A, B and C. Each phase is offset by 120 degrees, 360 degrees being the span of one complete cycle.
Motor Output Rating
Speed
The speed at which an induction motor operates is dependent upon the input power frequency and the number of electrical magnetic poles for which the motor is wound.
The higher the frequency, the faster the motor runs. The more poles the motor has, the slower it runs. The speed of the rotating magnetic field in the stator is called synchronous speed.
To determine the synchronous speed of an induction motor, the following equation is used:
Actual full-load speed (the speed at which an induction motor will operate at nameplate rated load) will be less than synchronous speed. The difference between synchronous speed and full-load speed is called slip. Percent slip is defined as follows:
A motor with a slip of less than 5% is called a normal slip motor. Motors with a slip of 5% or more are used for applications requiring high starting torque (conveyor) and/or higher than normal slip (punch press) where, as the motor slows down, increased torque allows for flywheel energy release.
Title: | AC Motor Selection and Application Guide – General Electric |
Format: | |
Size: | 282 KB |
Pages: | 32 |
what is the full load speed
Is it possible to run motor on direct 3phase supply without using any drive..
and if possible at what speed it will run
its posible ,but the speed is fixed between the charge and motor , in this condition is absolutely necessary,
that motors work close to synchronous speed or your sleep must be nera to 5 per cent.
you must put a thermal protection ,put away the motor if the steady state ,current is more than 15 percent than nominal current-
All materis very help me in do my job, thank you very must
I want to fit the EEP portal. Greetings.
I have a question for you: What if speed of induction motor reaches synchronous motor?
Hi Ben
Induction motor never rotate in synchronous speed, I hope that U know about slip, induction motor reach the synchronous speed means the slip is zero,if slip is zero means induction motor speed also zero.but it not possible induction motor catch the synchronous speed
the motor never workh a synchronous speed because in this position is not util because in this point the par developed its theoretical null.
the most near situation at the synchronics speed,is when you put i on the motor without charge ,then the energy that motor is wasting es the necessary only for the loos –
not speed is zero the par or torque es null for synchronous speed.and the motor left the utility-
Not possible,induction motor never run on synchronous speed
