Motor Starters
Welcome to this EATON’s guide, which is about starters, devices that control the use of electrical power to equipment, usually a motor. As the name implies, starters “start” motors. They can also stop them, reverse them, accelerate them, and protect them.
Basics Of Motor Starters And Contactors
Basics Of Motor Starters And Contactors (on photo: Eaton Magnetic Motor Starter)
Starters are made from two building blocks, contactors and overload protection:
  • Contactors control the electric current to the motor. Their function is to repeatedly establish and interrupt an electrical power circuit.
  • Overload Protection protects motors from drawing too much current and overheating, from literally “burning out.”
The Contactors
A contactor can stand on its own as a power control device, or as part of a starter. Contactors are used in applications ranging from the light switch to the most complex, automated industrial equipment.
Contactors are used by electrical equipment that is frequently turned off and on (opening and closing the circuit), such as lights, heaters, and motors.
A starter is made up of a controller (most often a contactor) and overload protection
Figure 1 – A starter is made up of a controller (most often a contactor) and overload protection
Whatever the application, the function of the contactor is always the same: to make and break all power supply lines running to a load. Or, as defined by NEMA, to repeatedly establish and interrupt an electrical power circuit.
We’ll start by talking about the building blocks of a starter: the contactor and overload protection. We will then conclude with a discussion on starters.
Here are the topics that we will cover:
  1. The Contactor (magnetic contactor, how the contactor operates, contact life etc.)
  2. Overload Protection (How motors work, what is an overload?, overload relay, tripping etc.)
  3. The Starter (magnetic motor starter, starter circuitry, types, standards and ratings etc.)
  4. Helping the Customer (NEMA or IEC?, checking the motor nameplate etc.)
Title:Basics Of Motor Starters And Contactors by EATON
Pages:37
  1. Alois Jaka
    May 31, 2017
    this is great ‘
  2. amdou bah
    May 30, 2017
    Helps
  3. sakthi
    Dec 15, 2015
    Neutral
  4. dharam pal
    Dec 14, 2015
    Namskar,
    Thanks for your valuable information.
forty nine  ⁄    =  seven
