SCADA Navigation Configuration
Global sections of the SCADA database configuration need to be updated to allow navigation to and from the site to be consistent with all other sites.
Technical specification for SCADA and automation systems
Technical specification for SCADA and automation systems (on photo: Clearscada scada system demo; credit: Drew Carnell via Youtube)
The following is required:
  • The hydraulic symbol for the site (Graphics.Hydraulic) shall be embedded on the hydraulic overview and displayed to align with other sites both horizontally and vertically, if applicable.
  • The main menu ($Root.Default) needs to be updated to provide navigation to the site. Configure the advanced pick-action menu on the appropriate menu button to include a navigation hyperlink to the overview (Graphics.Overview) of the new site. Ensure sites in the same graphical location are grouped. E.g. Sandgate; and ensure the menu is displayed alphabetically.
SCADA alarms
SCADA alarms are standard per device. Alarm and event severities shall be as defined in the template. Hunter Water shall define alarm severities used for developing new templates. Alarm severities are:
  1. Delayed Low
  2. Delayed Medium
  3. Delayed High
  4. Low
  5. Medium
  6. High
  7. Critical
If the severity of an alarm is deemed to be one of those that are delayed, the following extra configuration must be completed once per point:
  1. Alarm redirections must be enabled
  2. A new redirection is to be configured as the following:
    • Trigger Type: Auto
    • Trigger State: Uncleared
    • Action: ~Config.Redirections.Delay Time Change of Priority o Low Severity: Delayed Low
    • High Severity: Delayed High
    • Direction: Either
    • Delay:
    • Abort State: Cleared
    • Active From: 00:00
    • Active To: 00:00
When the severity of an alarm is configured, if the object is a DNP3 point, this will dictate the DNP3 class the point is to be configured with. The following table shows the relationship between SCADA alarm severity and DNP3 class data that is required.
All points within the SCADA site that are configured with an alarm shall be configured with an Alarm View and a Default View.
Title:Standard technical specification for SCADA and automation systems by Hunter Water Corporation
Pages:62
  1. Steven Birali
    Feb 08, 2023
    Could you please give technical Specification of SCADA for automation?
  2. Steven Birali
    Feb 08, 2023
    I want you to give me general technical specification of Scada
  3. Vincent NZEYIMANA
    Aug 01, 2022
    I’m looking for SCADA system specification in Electrical field.
    Thanks.
sixty four  ⁄    =  8
