Electrical Engineering
Subscribe to EEP's Technical Articles and be a better electrical engineer!
Electrical engineering books and guides
Transformer Switch Powering a Data Centre (interxion.com)
Electrical engineering is a field of engineering  that generally deals with the study and application of electricity, electronics  and electromagnetism. Companies and industry experts has been always releasing technical books and guides in order to spread their knowledge.
On this page you can find very usefull books and guides related to electrical science, industry, automation and telecommunications.
All documents, software and books are free to download and preserved only to registered users. Login and registration links are located on the bottom of portal or use links below.
Member Login | Register
Electrical books & guides
No.DescriptionDownload
1The ART & SCIENCE of protective relaying
2Electrical power supply and distribution star
3Energy-Efficient Electric Motor Selection Handbook
4Modern Signal Processing
5Network Protection And Automation Guide
6PLC – Programmable Logic Controller star
7Power plant acoustics
8Coordinated Power Systems Protection
9Telecommunications Building Cabling Systems Planning, Design
10UPS selection, installation and maintenance
11Antenna Systems Guide
12Engineering Symbology, prints and drawing star
13Grounding and Bonding
14Handbook of electrical safety
15Handbook of electrical science VOL. 1-4
16Personal Protective Grounding for Electric Power Facilities and Power Lines
17Photovoltaic Power Systems
18Automation Solution Guide
19Electrical Installation Guide star
20Harmonic detection and filtering
21Introduction to Motor and Generator
22Fact Worth Knowing About Frequency Converters
23Medium Voltage Cables – Construction Standard Specifications
24Electrical Power Supply And Distribution
25ABB – Electrical Installation Handbook PART I star
26ABB – Electrical Installation Handbook PART II
27Instrument-Transformers – Part 1 of 3 Current Voltage Transformers
28Instrument-Transformers – Part 2 of 3 Current Voltage Transformers
29Instrument-Transformers – Part 3 of 3 Current Voltage Transformers
30Electrical Engineering Formulas
31Guide To Forms Of Separation In Low-Voltage SwitchGear and ControlGear
32How Power Factor Corection Works
33How To Apply Capacitors To Low Voltage Power Systems
34ABB – Power Factor Correction And Harmonic Filtering In Electrical Plants
35Power Factor – The Basics
36Transmission And Distribution Electrical Engineering
37Danfoss – From Real-World Applications star
38Lighting Handbook star
39HV AC Circuit breakers – IEC62271-100
40PROFIBUS – Cabling and Assembly star
41PLC – Theory and Implementation newbook
41A Simple Approach To Short Circuit Calculations newbook
42Best Practice Manual For Transformers newbook star
Don't miss anything
Powered by MailChimp
Leave a reply!
(free electrical software, guides and books)
Subscribe also to Technical Articles updates.
Advertisement
EEP - Advertise your business here
Electrical Engineering Video Lectures
Technical Categories
ePlusMenuCAD 10 RC1 released
Today we released ePlusMenuCAD 10 RC1! Why RC1 (release candidate 1)? Simply because Help is not written yet. It will...
Metric Unit Prefix Conversions
This video shows how to convert units with metric prefixes from one prefix to another by moving simply moving the...
Be extremelly carefull when racking in and racking out of circuit breaker
Arc flash incident, bad racking? There are many reasons causes arc flash incidents. Some of arc flash explosions occur when...
Close
