Home / Download Center / Electrical Engineering Books and Technical Guides / Electrical engineering guides / Basic wiring for motor control – Technical data guide
Wiring diagrams
Wiring diagrams show the connections to the controller. Wiring diagrams, sometimes called “main” or “constructiondiagrams, show the actual connection points for the wires to the components and terminals of the controller.
Basic wiring for motor control - Technical data
They show the relative location of the components. They can be used as a guide when wiring the controller. Figure 1 is a typical wiring diagram for a three-phase magnetic motor starter.
Typical Wiring Diagram
Figure 1 – Typical Wiring Diagram
Line diagrams show circuits of the operation of the controller
Line diagrams, also called “schematic” or “elementarydiagrams, show the circuits which form the basic operation of the controller. They do not indicate the physical relationships of the various components in the controller. They are an ideal means for troubleshooting a circuit.
Figure 2 shows a typical line or schematic diagram.
Typical Line or Schematic Diagram
Figure 2 – Typical Line or Schematic Diagram
Standardized symbols make diagrams easier to read
Both line and wiring diagrams are a language of pictures. It is not difficult to learn the basic symbols. Once you do, you are able to read diagrams quickly, and can often understand a circuit at a glance. The more you work with both line and wiring diagrams, the better you will become in analyzing them.
The American Standards Association (ASA) and the National Electrical Manufacturers’ Association (NEMA) are the agencies which are responsible for setting up and maintaining the symbol standards.
Because of these standards, you will be able to read all diagrams that come across your workbench.
Title:Basic Wiring for Motor Contol – Technical Data // EATON
Pages:14
29 Comments
  1. Tim Nelson
    Sep 10, 2023
    The control switch for an electric hoist I have was pulled out of the wiring harness on the motor. One of the 4 wires was broken so that reconnection is obvious. The other 3 wires were pulled out of the wiring harness. If I send you pictures of the wiring diagram on the underside of the harness cover and pictures of the harness and wires could you tell me which or the three unconnected wires plug into which of the 4 harness locations?
    Many Thanks
  2. Alif
    Sep 14, 2022
    I purchased used motorized honey extractor. The motor is not working and there is no smell also i had rradings on multimeter.
    Can you please help me figure out which wire goes where because the seller had it wired wrong.
    Much appreciated
  3. Thomas Green
    Sep 04, 2022
    Very straight forward and I would like to see the wiring diagram and any more detailed on how the indicator lights are integrated.
  4. Anooj AJ
    Aug 29, 2022
    Protection and Automation Engineers
  5. Shepherd Nakari
    May 28, 2022
    Helpful
  6. edward mwalimo
    Aug 16, 2021
    whats the price of this motor control panel
    • Waate Henry
      Sep 14, 2022
      Pls can you please send e a material that will help me to connect a pump to as panel then to a HMI
  7. graham banda
    Dec 05, 2020
    domestic wiring and motor control
    • Deginet Desalegn
      Jun 12, 2022
      pls send me some information
  8. Heri
    Sep 27, 2020
    Hay bos, thanks to this articles, btw can i reshare this with my language?
  9. Johnny
    Jan 04, 2019
    Knowledge of basic single- and three phase electrical systems including basic AC and DC motor control and safety measures on electrical equipment.
  10. Joseph
    Nov 02, 2018
    Really helpful
  11. Daniel Asare
    Jul 12, 2018
    Wow. Fantastic stuff here.
  12. Jim Curtis
    May 04, 2018
    Should have a fuse on control circuit and possibly show a transformer for control circuit in which more often than not one is used
  13. Daniel Amare
    Mar 09, 2018
    Really is the best college for practical knowledge base learning
  14. Christopher mwengwa
    Mar 07, 2018
    It is good keep it up
  15. siwema gama
    Mar 07, 2018
    thanks a lot, truly it’s helpful
  16. Devindraferreira
    Oct 15, 2017
    Thank you the information is very useful
  17. zaid nazik
    Aug 10, 2017
    i feel so appreciated for your efforts
  18. manoj sadh
    Jul 30, 2017
    thank you for this service its very useful for me
  19. Venkat
    Apr 12, 2017
    Good information
  20. Courage Agbenyeke
    Feb 10, 2017
    Thank you very much I really enjoyed it
  21. Muhammad imran shoukat
    Jan 29, 2017
    it is a good knowledge for learning.
  22. nelson laguna
    Mar 04, 2016
    I’ve known the control but the question is how do you actually connect the 3 wires coming from overload relayinto the connection box of the motor if it has 3 leads or 6 leads?
    Thanks..
    • Esteban Mariscal
      Apr 02, 2017
      Depending on your motors application (low or high voltage).
      In a 480vac application you’d wire the wires inside of the box 4-7 5-8 6-9… The 3 phases coming into the box from your overload would pair with wires 1,2,3 inside of the box.
    • Shafiq muavia
      Feb 27, 2018
      Best site for learning
  23. vivek pingal
    Jul 11, 2015
    thanks , its really help full for me . please help me to understand more circuits on panels
  24. Sandbhor Vishal
    Oct 11, 2013
    thank u very much
  25. PhP
    Oct 07, 2013
    Thank you so much!! This is helpful!! I am glad to be part of this site!!
forty four  +    =  forty nine
