Home / Download Center / Electrical Engineering Books and Technical Guides / Electrical engineering guides / Learn earth ground resistance principles, testing methods and applications
Why test grounding systems?
Good grounding isn’t only for safety. It is also used to prevent damage to industrial plants and equipment. A good grounding system will improve the reliability of equipment and reduce the likelihood of damage due to lightning or fault currents.
Over time, corrosive soils with high moisture content, high salt content, and high temperatures can degrade ground rods and their connections. So although the ground system when initially installed, had low earth ground resistance values, the resistance of the grounding system can increase if the ground rods are eaten away.
Grounding testers are indispensable troubleshooting tools to help you maintain uptime. With frustrating, intermittent electrical problems, the problem could be related to poor grounding or poor power quality.
Components of a ground electrode
That is why it is highly recommended that all grounds and ground connections are checked at least annually as a part of your normal Predictive Maintenance plan.
During these periodic checks, if an increase in resistance of more than 20 % is measured, the technician should investigate the source of the problem, and make the correction to lower the resistance, by replacing or adding ground rods to the ground system.
What affects the grounding resistance?
First, the NEC code 250-83-3 requires a minimum ground electrode length of 2.5 meters (8.0 feet) to be in contact with soil.
But, there are four variables that affect the ground resistance of a ground system:
  1. Length/depth of the ground electrode
  2. Diameter of the ground electrode
  3. Number of ground electrodes
  4. Ground system design
Title:Earth ground resistance – Principles, testing methods and applications – Fluke
Pages:16
  1. Manish Sah
    Sep 24, 2023
    Well knowledge always enrich the experience,so i think it as a good initiative.
  2. Patrick Toussaint
    Jul 10, 2020
    Très bon article. Merci de partager avec nous toutes ces précieuses informations.
  3. Samuel Francisco Pongo Porras
    Jul 09, 2020
    Excelente, sus enseñanzas son practicas, gracias
  4. Samer Mahmoud almasri
    Jun 10, 2020
    Your articles is too much good
  5. Pravin Chavan
    May 07, 2020
    For understanding with pictures
    So thanks very much
    And continue gave electrical information to us
    Thanks very much
eight  +  1  =
