Home / Download Center / Electrical Engineering Books and Technical Guides / Electrical engineering guides / Step-by-step guide to design and functional basics of electric cars
Basics of Electromobility
The term electric motor/generator is used instead of alternator, electric motor and starter. In principle, any electric motor can also be used as an alternator. When the electric motor/generator is driven mechanically, it supplies electrical energy as an alternator.
Design and Function Basics of Electric Cars - Step By Step For Engineers
Design and Function Basics of Electric Cars – Step By Step For Engineers
When the electric motor/generator is supplied with an electrical current, it works as a drive. Electric motors/generators used for propulsion are water-cooled. Air cooling would also be possible but complex due to space and the amount of heat generated.
In full hybrid vehicles (HEV), the electric motor/generator also functions as the starter for the combustion engine.
Three-phase synchronous motors are often used as the electric motor/generator. A three-phase motor is powered by a three-phase alternating current. It works with three coils that are arranged in a circle around the rotor to form the stator and are each electrically connected to one of the three phases.
Several pairs of permanent magnets are located on the rotor in this synchronous motor. Since the three coils are supplied sequentially with a current, together they generate a rotating electrical field that causes the rotor to rotate when the electric motor/generator is used to drive the vehicle.
Drive Units and High-Voltage Components
When used as an alternator, the movement of the rotor induces a three-phase alternating voltage in the coils that is transformed into a direct voltage for the high-voltage battery in the power electronics.
Normally so-called “synchronous motors” are used in vehicles. In this context, the term “synchronous” means “running in synchronism” and refers to the ratio of the rotation speed of the energised field in the stator coils to the rotation speed of the rotor with its permanent magnets.
The advantage of synchronous motors compared with asynchronous motors is the more precise control of the motor in automobile applications.
Strengths of the Electric Motor/Generator
The electric motor/generator is very environmentally compatible thanks to the lack of noise and harmful emissions. The electric motor/generator responds quickly, has good acceleration figures and a high level of efficiency. In contrast to combustion engines, electric motors supply their nominal power steplessly over a broad rpm range.
The maximum torque is available even at low rpm (i.e. when pulling away) and only drops once the motor reaches very high speeds. As a result, neither a manually operated transmission, an automatic transmission nor a clutch are required.
The direction of rotation of an electric drive motor is freely selectable. It can turn clockwise to move the vehicle forwards and counter-clockwise to reverse it.
Title:Design and Function Basics of Electric Vehicles – Volkswagen Group of America, Inc.
Pages:62
Design and Function Basics of Electric Vehicles For Service Engineers
10 Comments
  1. Kwok Wing Chan
    Feb 02, 2024
    some of the animals such as Cats like sleeping behind the car. There are some concerns that they are not aware of the EV cars moving as it it too quiet
  2. Jayeoba Babatunde
    Jan 24, 2023
    Please can somebody help me with the step by step material.
  3. Michael Fatokun
    Sep 17, 2022
    show me the steps to take build an electric cars …. and back up information to help me.. I too want an electric car ….
  4. Madhusudan Reddy Vanukuri
    Jul 27, 2022
    May I have step step Project Plan for designing Electric Vehicle?
  5. shane Chng
    Mar 25, 2022
    where is the step-by-step guide
  6. Tigran
    Sep 11, 2021
    But where is step-by-step guide?
    • Tron
      Sep 17, 2021
      Check the table where it mentions title, format, size, etc. – after the article. You have to download the pdf from the link “Right here”. It’s 62 pages
  7. Adit gupta
    Apr 11, 2021
    Informative and precise article.
    diagrammatic view explains many things easily
  8. Adit gupta
    Apr 11, 2021
    very informative and precise article.
    diagram made things clear.
  9. Shiva
    Nov 13, 2020
    I think about the recharged on driving mode by using motors
  −  five  =  four
