Harmonic Detection And Filtering
The frequency spectrum
The frequency spectrum is a practical graphical means of representing the harmonics contained in a periodic signal. The graph indicates the amplitude of each harmonic order. This type of representation is also referred to as spectral analysis. The frequency spectrum indicates which harmonics are present and their relative importance.
Devices causing harmonics are present in all industrial, commercial and residential installations. Harmonics are caused by non-linear loads.
Definition of non-linear loads
A load is said to be non-linear when the current it draws does not have the same wave form as the supply voltage.
Examples of non-linear loads
Devices comprising power electronics circuits are typical non-linear loads. Such loads are increasingly frequent and their percentage in overall electrical
consumption is growing steadily.
Examples include:
  • industrial equipment (welding machines, arc furnaces, induction furnaces, rectifiers),
  • variable-speed drives for asynchronous and DC motors,
  • office equipment (PCs, photocopy machines, fax machines, etc.),
  • household appliances (television sets, microwave ovens, fluorescent lighting, etc.),
  • UPSs.
Saturation of equipment (essentially transformers) may also cause non-linearcurrents.
Title:Harmonic Detection And Filtering by Schneider Electric
Pages:45
Download:Please login first
Don't miss anything!
Powered by MailChimp
  1. [...] This post was mentioned on Twitter by Electric Engineering, Electric Engineering. Electric Engineering said: Harmonic Detection And Filtering – FREE GUIDE http://t.co/9wjl6JU [...]
  2. [...] that the manufacturer shall provide in the documentation of the PDS, or on request, the current harmonic level, under rated conditions, as a percentage of the rated fundamental current on the power port.The [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Voltage Instrument Transformer (VT) – Introduction
Instrument transformers are primarily used to provide isolation between the main primary circuit and the secondary control and measuring devices....
A Simple Approach To Short Circuit Calculations
Why Short-Circuit Calculations Several sections of the National Electrical Code relate to proper overcurrent protection. Safe and reliable application of overcurrent protective...
Maintenance Of Molded Case Circuit Breakers (MCCB)
The maintenance of circuit breakers deserves special consideration because of their importance for routine switching and for protection of other...
Close
