Home / Download Center / Electrical Engineering Books and Technical Guides / Electrical engineering guides / High Voltage Engineering – The Practice and Theory
Power Network
In this book the term high voltage is used as a generic term to include all voltages higher than 1000 volts, although the emphasis is on the typical voltage levels used power systems. High voltages, however, feature in many applications that are not related to the power system.
High Voltage Engineering - Practice and Theory
High Voltage Engineering – Practice and Theory (on photo: Disconnecting Circuit Breakers; credit: ABB)
Typical examples are automotive ignition systems, cathode ray tubes as found in oscilloscopes and television sets. A schematic representation of a typical power system is shown in Fig. 1.1.
An important relationship in connection with power transmission is the following:
S = √3 V I (figure 1.1)
with S as apparent power in kVA, V as line-to-line voltage in kV and I the line current in A.[/info_box]
This equation clearly shows that, in order to transmit a fixed amount of kVA over a transmission line, a higher voltage is preferable as it results in lower currents. The lower currents are desirable as the losses and voltage drops due to the conductor resistance are lower.
This permits the use of thinner conductors.
Schematic representation of a power network
Figure 1.1 – Schematic representation of a power network
The use of higher voltages introduces a number of new aspects that have to be taken into  account in order to prevent current leakage or flashover due to inadequate insulation. In general all metals are conductors of electricity due to their higher conductivities, with copper and aluminium being the cost-effective choices.
Non-metals are generally non-conductors of electricity, i.e. insulating materials. These include gases in their non-ionized state – air at atmospheric pressure being the most generally applied substance of this type. Pure, deionised water is also an insulating material, but minute quantities of dissolved inorganic salts turn it into a conductor, despite the fact that the salt crystals are insulators when dehydrated.
Organic matter, such as wood, is also a good insulator when dry, but becomes conducting when moist. The properties of a number of substances are given in Table 1.1.
From this table air at atmospheric pressure is an obvious choice as an insulating material. This resulted in the widespread use of high voltage overhead lines and outdoor substations. It is however still necessary to support the high voltage conductors mechanically. For this purpose porcelain and glass have given good service as support or suspension insulators.
These insulators then appear parallel to the air insulation that surrounds the bare conductor. The interface between the porcelain or glass and air turns out to be a vulnerable region.
Table 1.1 – Properties of Conductors and Insulating Materials
In metal clad gas insulated systems (GIS), sulphur hexafluoride gas (SF6) is used as the main insulating medium. In addition, solid materials such as porcelain, glass and polymers are also used to support the high voltage conductors. Transformers and other equipment use mineral oil, either on its own or in combination with linen or paper.
In a properly designed system the above mentioned insulation systems should be able to perform reliably under normal voltage conditions as well as under abnormal overvoltage conditions. The main factor that may cause failure of insulation is overstressing, i.e. applying an electric field to the material that exceeds its capabilities and induces failure.
Typically, air at atmospheric pressure is a good insulator and a gap consisting of electrodes without sharp protrusions can easily withstand 20 kV/cm. However, at 30 kV/cm the air in the gap becomes ionized and breaks down, leading to a flashover, accompanied by a high short circuit current.
Lightning develops similarly when the build-up of electric charge in the cloud causes field conditions, leading eventually to a massive discharge in the form of a high current to ground.
Title:High Voltage Engineering – Practice and Theory by Dr JP Holtzhausen; Dr WL Vosloo
Pages:157
12 Comments
  1. Emery
    Jul 26, 2018
    This site is quite professional and technical and thorough, however, if this body of knowledge were taken further, you would have to concede to being a conspiracy site.
  2. Daniel
    Jul 25, 2018
    This site is the best Electrical Engineering site
  3. チョウ チョウテツ
    Jul 24, 2018
    this is very useful for electrical engineering
  4. Kudlappa.Basappa.Kadal
    Nov 15, 2015
    This is very useful for learners develop in their professional carrier.
  5. kennet memani
    Nov 15, 2015
    This is a really good informative site that is helping with a lot of things,plz keep it up you are really helpful much love Kenneth in South Africa
  6. Mohammed Rafi
    Dec 20, 2014
    Awesome site,Excellent material & notes for Fresh/Senior Elect.Engineers
  7. Hammed Abdulgafar
    Jul 04, 2014
    so good
  8. Old Dog
    Mar 08, 2013
    Very informative website. I Teach part time at Umpqua Community College and share your information and articles with all the apprentices.
  9. mazed_04eee
    Jan 07, 2013
    thank u very very much.Just awesome a site for electrical engineers.
  10. [email protected]
    Dec 21, 2012
    really it is too good
  11. mohammadreza nabati rad
    Nov 02, 2012
    I Have not seen any useful and informative site like this site even!
    It helped me in various situation
  12. mowafak sadeek
    Oct 17, 2012
    thank you for every think. I hope you the best and development
3  ×    =  thirty
