Home / Download Center / Electrical Engineering Books and Technical Guides / Electrical engineering guides / Metering Best Practices – A Guide to Achieving Utility Resource Efficiency
Energy and water metering
The purpose of this guide is to provide information on effective energy and water metering strategies, relevant technologies and communications, how to collect and use metered data, and how to develop a metering plan.
Metering Best Practices - A Guide to Achieving Utility Resource Efficiency
Metering Best Practices – A Guide to Achieving Utility Resource Efficiency (on photo: Schneider Electric’s PowerLogic PM8000; credit: voltimum.co.uk)
This guide is designed to serve as a resource for facility, energy, and water management and technical staff.
It does not try to represent the universe of metering-related material. Rather, it attempts to //
  • Provide background information on why metering is important.
  • Provide guidance on the structure of an effective metering program.
  • Provide information on metering and communications technologies.
  • Highlight common uses of metered data.
Facility, energy, and water resource managers, practitioners, and technical staff represent the prime audience of this document. The benefits of a comprehensive metering program extend from the site-level, up through to the national headquarters’ level.
A comprehensive metering program requires the participation of staff from key areas within the overall facilities organization including operations, maintenance, engineering, procurement, training, and administration.
While a given site may not have all of these areas as separate entities, these functions are provided for within the organization. These staff members are also part of the target audience of this guide.
A successful metering program requires cooperation, dedication, and participation at all levels and cannot succeed without everyone involved understanding the basic principles and supporting the efforts to acquire technically sound data regarding resource use within buildings or associated with delivery of an energy resource.
Title:Metering Best Practices – A Guide to Achieving Utility Resource Efficiency U.S. Department of Energy
Pages:106
50% Discount đź’Ą - Save 50% on all 90+ video courses with Enterprise Membership plan.
  1. mr wali
    Mar 18, 2021
    make this article simple please
  2. Yogendra Prasad
    Feb 26, 2020
    What is the best way to connect wire in Energy Meter terminal? Should I use lugs at the end of the cable or connect wire directly to meter terminal without lugs?
    • abdul
      Mar 18, 2021
      usage of lugs in meter terminal connection make readings more accurate
  3. Foluso Omolewa
    Mar 22, 2018
    It is amazing the quality and the extent of the engineering knowledge being passed to Engineers out there. Thank you for the good job you are doing
  4. Bhaskar Santra
    Dec 29, 2016
    Its good for electrical and electronics engineers to gather knowledge theoretically and practically. EEP had help me to get better knowledge in field job with extreme knowledge about the technical systems. I thank to EEP for their support to electrical and electronics people.
  ⁄  7  =  one
