Premium Membership β™•
Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / Energy transmission and distribution over lines and cables in power systems
Characteristics of Power Lines
When the current is flowing through the metallic conductors electric and magnetic fields are created and the electric power is carried by these fields (Poynting’s vector S = E Γ— H).
Energy transmission and distribution over lines and cables in power systems (photo credit: Etap)
In power systems the primary task of a line is the secure transport of powers between different locations in the grid. Utilized are either overhead lines or cables. They differ in their construction and the operating conditions and therefore their usage is different.
A considerable difference is the cost: at equal voltage levels the costs for a cable can be up to about 10 till 20 times higher than those of an overhead line. Therefore the construction of overhead lines is preferred from an economical point of view.
The geometry of overhead lines or cables is characterized by that it is not varying along one direction, namely along the direction of the line. Therefore, a parallel configuration of the conductors is considered. This is an approximation which considerably simplifies the mathematical calculation without compromising the accuracy of the results.
A simplified energy distribution system
Figure 1 – A simplified energy distribution system
Power lines can be considered as a homogenous construction possibly including multiple single conductors. Thereby, the properties are characterized by distributed parameters (e.g., inductance per line length in mH/km). A line can therefore a priori not be described by lumped parameters as known from the theory of circuits.
Simplified, a line section can though be modelled by a Ξ -configuration using lumped circuit elements, i.e. impedances. Depending on the type of analysis, this simplification is valid up to a certain line length.
Reasons for High Transmission Voltages
Figure 1 shows a simplified direct current transmission system. Here, a load is fed with electric power by a generator through a power line. As the line is resistive, a voltage drop will occur along the line:
The voltage at the generator UG is higher than the voltage at the load UL. Um denotes the voltage in the middle of the line.
Title:Electric Power Systems – Electric Power Transmission and DistributionΒ – Goran Andersson; EEH – Power Systems Laboratory ETH Zurich
Pages:188
Electric Power Systems – Electric Power Transmission and Distribution – Goran Andersson; EEH – Power Systems Laboratory ETH Zurich
50% Discount πŸ’₯ - Save 50% on all 90+ video courses with Enterprise Membership plan.
  1. Swapnil
    Sep 14, 2019
    Good videos. I like it from plc
  +  seventy five  =  83
