Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / Fundamentals of High Voltage Circuit Breakers, Switching Stresses and Failure Modes
HV circuit breakers
The thesis contributions can be mainly divided into three phases: high voltage circuit breakers failure modes and effects analysis, probabilistic models and maintenance optimization. The extra phase is the investigation of stresses of HV circuit breakers from the simulation and the statistical method.
Fundamentals of High Voltage Circuit Breakers, Switching Stresses and Failure Modes (on photo: 345KV SF6 3PH Circuit Breaker; credit: wolfartistic.deviantart.com)
The organization of this thesis can be described as followed:
Fundamentals of HV circuit-breakers composed of functions and components of HV circuit-breakers, types of HV circuit-breakers and switching transients are represented in Chapter 2.
Chapter 3 represents the switching stresses of HV circuit-breakers. In this chapter, the stresses of HV circuit-breakers regarding different types of applications are investigated by simulation method. The other stresses regarding the number of faults and their severity are investigated by using statistical method.
Based on the failure database developed by the Institute of Power Systems, Darmstadt University of Technology, it is possible to investigate failures of HV circuit-breakers by using a failure modes and effects analysis method. The chapter 4 describes how to conduct this process and presents the result of investigation.
The risk assessment is also considered in this chapter.
The fundamentals of probability and reliability are first introduced in chapter 5. Then developed models, a treeing model and a cascading reliability model are introduced. With these models, the reliability and probability of HV circuit-breakers subject to failures can be determined.
Simulation diagram of a test radial 110 kV system
The application of Markov process used to investigate steady-state probabilities is introduced in chapter 6. The parallel Markov model for HV circuit-breakers is developed to examine the state probabilities. Different types of HV circuit-breakers with different driving mechanisms are taken into consideration.
Chapter 7 is the last part of this thesis representing cost structure analysis and maintenance optimization. A decision matrix approach is implemented in order to figure out the importance of parameters relating to costs of HV circuit-breakers. Apart from cost structure analysis method, maintenance optimization by using different methods is introduced in this chapter.
Finally, the conclusion is made in chapter 8 to summarize the results of this thesis and to propose the direction of the future development.
Research Objectives
The maintenance programs of HV circuit-breakers have been long performed by using the manufacture guidelines and experiences of operators. They have hardly been proved that they are really effective in terms of performance and costs. With emerge of deregulation electricity markets, maintenance costs considered as the large part of operation costs of utilities should be reduced in order to keep competitiveness of utilities.
To design new and optimal maintenance programs, it requires the knowledge of failure database analysis, failure modes and effects analysis, reliability investigation and risk assessment.
The objectives of this work are mainly comprised of those mentioned aspects. The failure database collected from utilities is deeply investigated to establish the probabilistic models.
These models can represent the probability of failures and how the failures are developed during the lifetime of HV circuit-breakers.
Title:Fundamentals of High Voltage Circuit Breakers, Switching Stresses and Failure Modes – M. Sc. Phuwanart Choonhapran
Pages:171
20  ⁄  two  =
