Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / Guide to power distribution systems for electrical engineers
Power distribution systems
Several new factors to consider in modern power distribution systems result from two relatively recent changes. The first recent change is utility deregulation. The traditional dependence on the utility for problem analysis, energy conservation measurements and techniques, and a simplified cost structure for electricity has changed.
The second change is less obvious to the designer yet will have an impact on the types of equipment and systems being designed.
It is the diminishing quantity of qualified building electrical operators, maintenance departments and facility engineers. Modern electric power technologies may be of use to the designer and building owner in addressing these new challenges.
An example of three-source spot network
An example of three-source spot network (click to expand scheme)
The advent of microprocessor devices (smart devices) into power distribution equipment has expanded facility owners’ options and capabilities, allowing for automated communication of vital power system information (both energy data and system operation information) and electrical equipment control.
These technologies may be grouped as:
  1. Power monitoring and control
  2. Building management systems interfaces
  3. Lighting control
  4. Automated energy management
  5. Predictive diagnostics
Basic principles
The best distribution system is one that will, cost-effectively and safely, supply adequate electric service to both present and future probable loads—this section is included to aid in selecting, designing and installing such a system.
The function of the electric power distribution system in a building or an installation site is to receive power at one or more supply points and to deliver it to the individual lamps, motors and all other electrically operated devices.
The importance of the distribution system to the function of a building makes it almost imperative that the best system be designed and installed.
Title:Guide to power distribution systems for electrical engineers by EATON
Pages:120
Further Study – The Ten Most Dangerous Noises in a Low-Voltage Substation
  1. Htet Wai Lynn
    Feb 07, 2019
    The world is facing problems of power Generation shortage, operational cost and high demand in these days. The main aim of this article is to know power generation methods, techniques and economical strategy which methods are suitable for individual country on the base its own natural resources, technical expertise and economy.
    This article is providing and guiding a best opportunity to select the right method and tecnique for right and economical power generation after study power generation, methods, Techniques and economical strategy
    Many countries are producing the power against its opportunies and wrong methods. Every country can produce the power denpen upon its own local opportunits and resoucres under the guidlines of this article and its recoomendations.
  2. Htet Wai Lynn
    Feb 07, 2019
    reduce losses of electricity in our country
