Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / A case study on SCADA implementation in 220 kV substation
200/110/11kV Shivgiri substation Bijapur is newly installed substation. Under IES project, automation of new substation is done through Substation Automation System (SAS) using IEC 61850. The functions performed by Substation Automation (SA) system are in, general, switch control, data monitoring, protection etc.
A case study on SCADA implementation in 220 kV substation (photo credit: nissi.co.in)
In IEC 61850, these functions are broken into low-level functions called sub-functions.
Each sub-function is performed by the IED installed in the substation. Each IED can perform one or many sub functions. A set of sub-functions is integrated together to realize a substation automation function. These communicate with each other through Local Area Network in the substation.
Levels defined in IEC 61850
Figure 1 – Levels defined in IEC 61850
Specific syntax and semantics are defined for communication between sub-functions. All the possible sub-functions have been standardized in IEC 61850. Information produced and required by each substation is given in the IEC 61850 standard.
The sub functions are assigned at three levels as shown in Figure 1 above:
  1. Process level
  2. Bay level
  3. Station level
SCADA equipment in substation
220/110/11kV substation control room is provided with Bay Control and Protection panel and Protection panel by ABB. All the ABB panels are equipped with 4 IEDs used for protection and control.
ABB’s IED 670 series provides reliable, efficient and flexible protection, monitoring and control for all applications in sub-transmission and transmission systems.
IED provides a common powerful hardware platform and an extensive hardware-independent, modular function library. Setting, commissioning and maintenance procedures of all IED are fast and simple. All are similar hence user can learn about one to know them all. These can communicate easily with IEC61850.
Title:A case study on SCADA implementation in 220 kV substation – Vinuta V Koluragi, M.Tech(Power and Energy Systems) Assisstant Professor
Pages:11
A case study on SCADA implementation in 220 kV substation – Vinuta V Koluragi1, M.Tech(Power and Energy Systems) Assisstant Professor
  1. Momodu S I
    Aug 30, 2017
    Why can’t we use 12kv DC as tripping unit for substations, which can make us use same parts with vehicle.
  2. Aghafierhenwaen Osasere
    Dec 19, 2016
    I am a professional in SCADA Technology, please can I be considered in any post in your Company? Please contact me.+2347037065952
72  +    =  seventy five
