Heating and Cooling With a Heat Pump
Introduction
If you are exploring the heating and cooling options for a new house or looking for ways to reduce your energy bills, you may be considering a heat pump. A heat pump can provide year-round climate control for your home by supplying heat to it in the winter and cooling it in the summer. Some types can also heat water.
In general, using a heat pump alone to meet all your heating needs may not be economical. However, used in conjunction with a supplementary form of heating, such as an oil, gas or electric furnace, a heat pump can provide reliable and economic heating in winter and cooling in summer.
If you already have an oil or electric heating system, installing a heat pump may be an effective way to reduce your energy costs.
Energy Management in the Home
Heat pumps are very efficient heating and cooling systems and can significantly reduce your energy costs. However, there is little point in investing in an efficient heating system if your home is losing heat through poorly insulated walls, ceilings, windows and doors, and by air leakage through cracks and holes.
Title:Heating and Cooling With a Heat Pump
Pages:32
Download:Please login first
Heating And Cooling With Heat Pump
Don't miss anything!
Powered by MailChimp
  1. [...] engineering with a high level of efficiency. Ultimately, the consumption of energy for lighting, heating and cooling depends on both the building use and user behaviour. These are indefinite factors for determining [...]
  2. [...] = 60; Figure 1: Typical Heat Pump Unit.The heat pump transfers the heat between the heating/cooling distribution system and the earth connection. It is the basic building block of the GSHP system. [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Guide to Combined Heat and Power Systems
Summary The guide is organized into topics that address many of the fundamental issues encountered in planning a CHP project...
SCADA Security Attacks
SCADA systems are used to control and monitor physical processes, examples of which are transmission of electricity, transportation of gas...
Relationship Between Earthquakes And Substations
To secure and protect substation equipment from damage due to a seismic event, the relationship between earthquakes and substation components...
Close
