Power substations books
Electricity generation
A substation that has a step-up transformer increases the voltage while decreasing the current, while a step-down transformer decreases the voltage while increasing the current for domestic and commercial distribution. The word substation comes from the days before the distribution system became a grid. The first substations were connected to only one power station where the generator was housed, and were subsidiaries of that power station.
Equipment in substation
Substations generally have switching, protection and control equipment and one or more transformers. In a large substation, circuit breakers are used to interrupt any short-circuits or overload currents that may occur on the network. Smaller distribution stations may use recloser circuit breakers or fuses for protection of distribution circuits. Substations do not usually have generators, although a power plant may have a substation nearby. Other devices such as power factor correction capacitors and voltage regulators may also be located at a substation.
Substations may be on the surface in fenced enclosures, underground, or located in special-purpose buildings. High-rise buildings may have several indoor substations. Indoor substations are usually found in urban areas to reduce the noise from the transformers, for reasons of appearance, or to protect switchgear from extreme climate or pollution conditions.
Where a substation has a metallic fence, it must be properly grounded (UK: earthed) to protect people from high voltages that may occur during a fault in the network. Earth faults at a substation can cause a ground potential rise. Currents flowing in the Earth’s surface during a fault can cause metal objects to have a significantly different voltage than the ground under a person’s feet; this touch potential presents a hazard of electrocution.
All documents, software and books are free to download and preserved only to registered users. Login and registration links are located at the top of the portal.
Don't miss anything!
Single-Phase Power vs Three-Phase Power | EEP
[...] OF ENERGYABB DrivesTECHNICAL GUIDESDanfossTHE HEATING BOOKHVACDESIGN GUIDESRelaysRELAY IN DETAILSPower SubstationsMAINTENANCE, LANRenewable energySOLAR, WIND, HYDROFeatured BookGuide To Forms Of Separation – BS EN [...]
engrwaqas_11
dear,
Regards,
Waqas Ahmed
subhransu
ANANDAN
DEAR SIR
PL HELP
ANANDAN
diamond
thanks a lot
