Home / Download Center / Electrical Engineering Books and Technical Guides / Power substation guides / Inspection and Test Procedures For Electrical Power Equipment and Systems
Acceptance Testing
The guidance of an experienced testing professional should be sought when making decisions concerning the extent of inspection and test procedures for electrical power equipment and systems.
It is necessary to make an informed judgment for each particular system regarding how extensive a procedure is justified.
The approach taken in these specifications is to present a comprehensive series of tests applicable to most industrial and larger commercial systems. In smaller systems, some of the tests can be deleted. In other cases, a number of the tests indicated as optional should be performed.
Likewise, guidance of an experienced testing professional should also be sought when making decisions concerning the results of test data and their significance to the overall analysis of the device or system under test.
Careful consideration of all aspects of test data, including manufacturer’s published data and recommendations, must be included in the overall assessment of the device or system under test.
The document is divided into twelve separate and defined sections:
  1. General Scope
  2. Applicable References
  3. Qualifications of Testing Organization and Personnel Division of Responsibility
  4. General
  5. Power System Studies
  6. Inspection and Test Procedures
  7. System Function Test
  8. Thermographic Survey
  9. Electromagnetic Field Testing
  10. Reference Tables
  11. Various Informational Documents
Section 7 consists of sections specific to each particular type of equipment. Within those sections there are, typically, three main bodies of information: Visual and Mechanical Inspection, Electrical Tests and Test Values.
Inspection and test procedures (section 7)
Section 7 is the main body of the document with specific information on what to do relative to the inspection and acceptance testing of electrical power distribution equipment and systems. It is not intended that this document list how to test specific pieces of equipment or systems.
  • Switchgear and Switchboard Assemblies
  • Transformers, Dry-Type, Air-Cooled, Low-Voltage, Small
  • Transformers, Dry-Type, Air-Cooled, Large
  • Transformers, Liquid-Filled
  • Cables, Low-Voltage, Low-Energy – Reserved
  • Cables, Low-Voltage, 600-Volt Maximum
  • Cables, Medium- and High-Voltage
  • Metal-Enclosed Busways
  • Switches, Air, Low-Voltage
  • Switches, Air, Medium-Voltage, Metal-Enclosed
  • Switches, Air, Medium- and High-Voltage, Open
  • Switches, Oil, Medium-Voltage
  • Switches, Vacuum, Medium-Voltage
  • Switches, SF6, Medium-Voltage
  • Switches, Cutouts
  • Circuit Breakers, Air, Insulated-Case/Molded-Case
  • Circuit Breakers, Air, Low-Voltage Power
  • Circuit Breakers, Air, Medium-Voltage
  • Circuit Breakers, Oil, Medium- and High-Voltage
  • Circuit Breakers, Vacuum, Medium-Voltage
  • Circuit Breakers, SF6
  • Circuit Switchers
  • Network Protectors, 600-Volt Class
  • Protective Relays, Electromechanical and Solid-State
  • Protective Relays, Microprocessor-Based
  • Instrument Transformers
  • Metering Devices
  • Metering Devices, Microprocessor-Based
  • Regulating Apparatus, Voltage, Step Voltage Regulators
  • Regulating Apparatus, Voltage, Induction Regulators
  • Regulating Apparatus, Current – Reserved
  • Regulating Apparatus, Load Tap-Changers
  • Grounding Systems
  • Ground-Fault Protection Systems, Low-Voltage
  • Rotating Machinery, AC Induction Motors and Generators
  • Rotating Machinery, Synchronous Motors and Generators
  • Rotating Machinery, DC Motors and Generators
  • Motor Control, Motor Starters, Low-Voltage
  • Motor Control, Motor Starters, Medium-Voltage
  • Motor Control, Motor Control Centers, Low-Voltage
  • Motor Control, Motor Control Centers, Medium-Voltage
  • Adjustable Speed Drive Systems
  • Direct-Current Systems, Batteries, Flooded Lead-Acid
  • Direct-Current Systems, Batteries, Vented Nickel-Cadmium
  • Direct-Current Systems, Batteries, Valve-Regulated Lead-Acid
  • Direct-Current Systems, Chargers
  • Direct-Current Systems, Rectifiers – Reserved
  • Surge Arresters, Low-Voltage
  • Surge Arresters, Medium- and High-Voltage
  • Capacitors and Reactors, Capacitors
  • Capacitors and Reactors, Capacitor Control Devices – Reserved
  • Capacitors and Reactors, Reactors, Shunt and Current-Limiting, Dry-Type
  • Capacitors and Reactors, Reactors, Shunt and Current-Limiting, Liquid-Filled
  • Outdoor Bus Structures
  • Emergency Systems, Engine Generator
  • Emergency Systems, Uninterruptible Power Systems
  • Emergency Systems, Automatic Transfer Switches
  • Communications – Reserved
  • Automatic Circuit Reclosers and Line Sectionalizers, Automatic Circuit Reclosers, Oil/Vacuum
  • Automatic Circuit Reclosers and Line Sectionalizers, Automatic Line Sectionalizers, Oil
  • Fiber-Optic Cables
Title:Standard For Acceptance Testing Specifications For Electrical Power Equipment and Systems – NETA
Pages:259
Standard For Acceptance Testing Specifications For Electrical Power Equipment and Systems - NETA
