Electrical Protection Systems
Electrical power system operates at various voltage levels from 415 V to 400 kV or even more. Electrical apparatus used may be enclosed (e.g. motors) or placed in open (e.g. transmission lines). All such equipment undergo abnormalities in their life time due to various reasons.
Power System Protection Practices // ABB
For example, a worn out bearing may cause overloading of a motor. A tree falling or touching an overhead line may cause a fault.
A lightning strike (classified as an act of God!) can cause insulation failure. Pollution may result in degradation in performance of insulators which may lead to breakdown. Under frequency or over frequency of a generator may result in mechanical damage to it’s turbine requiring tripping of an alternator.
Even othervise, low frequency operation will reduce the life of a turbine and hence it should be avoided.
It is necessary to avoid these abnormal operating regions for safety of the equipment. Even more important is safety of the human personnel which may be endangered due to exposure to live parts under fault or abnormal operating conditions. Small current of the order of 50 mA is sufflcient to be fatal!
Whenever human security is sacrificed or there exists possibility of equipment damage, it is necessary to isolate and de-energize the equipment.
Designing electrical equipment from safety perspective is also a crucial design issue which will not be addressed here.
To conclude, every electrical equipment has to be monitored to protect it and provide human safety under abnormal operating conditions. This job is assigned to electrical protection systems. It encompasses apparatus protection and system protection.
Here, on this page you will find 10+ ABB’s power system protection practices that can be of great help to protection engineers and others. Guides are free to download.
No.DescriptionDownload
1Electrical Safety New
2Relay Coordination and Selective Protection New
3MV Feeder Short-circuit Protection New
4MV Feeder Earth-fault Protection New
5Protection of HV Transformers New
6Protection of Meshed Networks New
7Protection of Shunt Capacitors Banks New
8Motor Protection New
9Protection of Synchronous Generators New
10Backup protection New
11Automatic Reclosing New
12Impedance-based Fault Location New
Complete guide to the good protection of medium voltage networks New
Elements of power distribution systems New
Working with trip characteristic curves of low voltage circuit breakers New
7 Comments
  1. Azegbea Jonathan
    Feb 08, 2018
    This is a very standard and concise way. Thanks for the job.
  2. TEMMAM
    Oct 05, 2016
    It’s very important information for an engineer for details and depth in electrical engineering and mastering the note calculated for each part of the electrical installation Low Voltage and Medium Voltage.
  3. Rommel Diaz
    Jun 08, 2016
    this website is very helpful to electrical engineers. good work!
  4. mahendrakumar
    Feb 14, 2015
    this website very useful to know about practically what happening in electrical terms especially in power systems….would you help to download totally power system in single book.because i search lot of websites for some practical terms about power systems.
    thank you for your regular updates,,,
  5. pramod kumar yadav
    Feb 12, 2015
    What is different from kva &kvar
    • Anwar Pasha
      Feb 22, 2015
      I think your question is: “What is the difference between KVA and KVAr”
      KVA is the apparent Power
      and KVAr is the reactive power. In case of inductive circuit the current lags behind the voltage and in case of capacitive circuit current leads the voltage..
  6. ram
    Feb 11, 2015
    this site is so good and I am really addicted to this.
