Contact System
Electrical contact
The word “contact” not only describes the conductive connection of two mechanically separate electrical conductors, but also the conductive parts (contacts) even if they are not touching. Contacts comprise:
  • Non switching contacts as in connectors being opened only for sen/ice or installation (e.g. screw connections)
  • Sliding contacts
  • Plug contacts to carry but not to switch current
  • Switching contacts as in relays, contactors and switchgear
Relay contacts are physically separate but switchable electric conductors designed to make an electrical connection, carry the load current, break the circuit and electrically isolate the load from the supply. How well the contact system actually performs is dependant on the suitability of the contact material, the contact arrangement and the mechanical
design.
An ideal relay contact would consist of highly conductive metal with chemically clean surfaces (no oxidation) and a large, wear resistant, effective contact area. Open contacts would ideally have infinite dielectric strength for electrical isolation. Unfortunately, actual relay contacts do not have these characteristics. An optimal contact material with high conductivity, resistance to oxidation or chemical reactions and resistance against wear and thermal influences during switching can only be a compromise.
Design and cost clearly limits parameters such as the size of contact area, contact forces, relay sensitivity, and the need for big contact gaps for high dielectric strength.
Title:Contact System
Pages:52
Download:Please login first
Don't miss anything!
Powered by MailChimp
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Inspection of voltage drop in conductors
It is part of the inspection process to ensure that installed conductors have been correctly selected for current carrying capacity...
Induction Machines
Formulas The synchronous rotational speed ns and synchronous angular speed ws of a machine with p pole pairs running on...
Siemens – CO2 Capture Technology Ready for Big Projects
A pilot project covered by Siemens and E.ON has shown that emissions of the greenhouse gas carbon dioxide from any...
Close
