Line Protection With Distance Relays
Introduction
Distance relaying should be considered when overcurrent relaying is too slow or is not selective. Distance relays are generally used for phase-fault primary and back-up protection on subtransmission lines, and on transmission lines where high-speed automatic reclosing is not necessary to maintain stability and where the short time delay for end-zone faults can be tolerated.
Overcurrent relays have been used generally for ground-fault primary and back-up protection, but there is a growing trend toward distance relays for ground faults also.
Single-step distance relays are used for phase-fault back-up protection at the terminals of generators. Also, single-step distance relays might be used with advantage for back-up protection at power-transformer banks, but at the present such protection is generally provided by inverse-time overcurrent relays.
The Choice Between Impedance, Reactance, Or MHO
Because ground resistance can be so variable, a ground distance relay must be practically unaffected by large variations in fault resistance. Consequently, reactance relays are generally preferred for ground relaying.
For phase-fault relaying, each type has certain advantages and disadvantages. For very short line sections, the reactance type is preferred for the reason that more of the line can be protected at high speed. This is because the reactance relay is practically unaffected by arc resistance which may be large compared with the line impedance, as described elsewhere in this chapter. On the other hand, reactance-type distance relays at certain locations in a system are the most likely to operate undesirably on severe synchronizing power surges unless additional relay equipment is provided to prevent such operation.
Title:Line Protection With Distance Relays
Pages:26
Download:Please login first
Don't miss anything!
Powered by MailChimp
  1. [...] a max of two cycles operating time for current above twice relay rated current. Instantaneous overcurrent protection clears heavy internal faults immediately. This relay is available in two forms.Firstly for use with [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
LD Calculator
Description The LD Calculator is a small application dedicated to people who work in the lighting industry. It provide an...
LV circuit-breaker
Introduction The energy sources for electrical installations are AC generators and transformers. All these generators, however perfect, have an internal...
Relays – General
Relay technology The relay was invented more than 160 years ago. During the last 50 years it has undergone considerable...
Close
