Home / Download Center / Electrical Software and MS Excel Spreadsheets (Calculations of cables, voltage drop etc.) / Distribution transformer calculations – MS Excel Spreadsheet
Four Fast Transformer Calculations
Distribution transformer calculations spreadsheet provides fast calculations for the following: Determining the MV/LV transformer rating, calculating overcurrent protection device rating on the low voltage side of the transformer, calculating the prospective short circuit current and Calculating natural ventilation openings sizes required for the transformer room.
Distribution transformer calculations - MS Excel Spreadsheet
1. Determining the MV/LV transformer rating
Input parameters:
  • Primary rated voltage (kV.)
  • Secondary rated voltage (kV.)
  • Max. demand load (kW)
  • Power factor after correction
  • Transformer type
  • Permissible loading percentage (%)
  • The nearest standard transformer rating (KVA)
2. Calculating overcurrent protection device rating on the low voltage side of the transformer
3. Calculating the prospective short circuit current across the low voltage side of the transformer
4. Calculating natural ventilation openings sizes required for the transformer room.
Software:Distribution Transformer Calculations – MS Excel Spreadsheet
Version:
Developer:Mahmoud Salama
Price:FREE
32 Comments
  1. Simbo Jonathan
    Feb 20, 2024
    will appreciate to receive tranfomer calculations file
  2. nicolae
    Jan 05, 2023
    How can the parameter database be updated? I got a 1600kVA dry type transformer with lower losses than what is used as example.
  3. Eric Moluwoi
    May 04, 2022
    Try downloading it, but have restrictions
  4. Kelvin
    Sep 30, 2021
    Could anyone share the password of this Distribution Transformer Calculation sheet? It’s in protected mode. Need to unprotect it to understand calculations…
    • Amit D
      Aug 24, 2022
      Have you received the password, if yes, let me know also.
  5. sanjay sharma
    Aug 21, 2021
    Useful. However some basic mistakes are there like the unit of Impedance has been given in Ohm.mile which could not be correct. It should be just Ohm. Further the bottommost table(left side) is presented in a way which can not be called user friendly and technically not correct also.
  6. Muhammad Bilal
    Aug 19, 2021
    I want detail calculations related to the electrical LT HT panels
    CT/ VT calculations
    Breaker sizing
    Cable rating calculation
    If any one have please email me
    I em beginner level
  7. John Ledawo
    Mar 03, 2021
    I desire that you will help me improve based on the how technology has advanced.
  8. Muhammad Asim Hussain
    Mar 01, 2021
    it is simply great
  9. Hervin Hugo Colmenares Quiñones
    Feb 28, 2021
    EEP is the best way I have to update my knowledge in electrical engineering. This article is a sample of the great value of EEP in the world.
    • Fehintola Samson Olusola
      Mar 01, 2021
      This is so helpful. Thank you for this.
      But is would be better if you can define the terms use next time because of beginners. Thank you once again.
      • Ishfaq Ahmed
        May 05, 2022
        Please anyone send me in Email
  10. md.suzauddoula
    Dec 17, 2020
    it’s very good.
  11. Hakim Walya
    Apr 14, 2020
    I do recommend fellow technicians to make use of the portal. it has been of great value
    • muzaffar khan
      Apr 16, 2020
      How can i down load the templates
  12. Lakshman Rangaiah
    Feb 05, 2020
    I would like to have a low power transformer spread sheet work sheet
  13. Kevin Njoroge
    Sep 06, 2019
    Hi..what could be the cause of mccb heating up and giving out a smell then one pole changes colour to darkish… your response will be highly appreciated
  14. Mubinul Haque
    Oct 05, 2018
    sir, do you have single phase distribution transformer design excel file 6350/240 V, 50 Hz, it will very helpful for me. Thanks in advance .
  15. Romano Trevinati
    Jan 07, 2016
    Good day!
    How i can test the xls file? i’m not able to download….
    thanks for your attention
    Romano
  16. Madhavan
    Nov 25, 2015
    Please send lighting excell spread sheet
  17. Tony
    Oct 24, 2015
    EEP is very, very useful and it help me a lot.
    Thank you very much for being part of my success.
  18. Ankush Sable
    May 16, 2015
    Dear Sir,
    Please tell me how to calculate tapping of distribution transformer. Please send the formulas for calculating tapp.
    Thank You!!
  19. aviran
    Mar 04, 2015
    please let me know how to design the foil of the distribution transformer , does any one have a design book?? if i have the power data what else i need to do? thank you all!!
  20. aviran
    Mar 02, 2015
    this is great portal , i need your help please.
    i need to design distribution power transformer , and i need to know how!
    do you have any books? sources of design?
  21. Juan Miguel
    Oct 14, 2014
    Great website to all electrical engineering students and for my work.
  22. K S P R M VITTAL
    Sep 03, 2014
    EEE is very very useful web site electrical engineers.I learnt more from this.
  23. Bharathakumar Menon
    Aug 25, 2014
    It is very useful
  24. Ryan
    Aug 25, 2014
    The link isn’t working for me :/
    • Designer
      Jun 12, 2015
      If you want more proffesionally distribution transformer test report xls file please contackt with by e-mail transformersdesign hotmail.com
      • Ivar Ling
        Nov 08, 2020
        I would like to get xls. Calculate sheet template
  25. murugesan
    Aug 24, 2014
    good very useful thanks
  26. Mehdi Hosseini
    Aug 24, 2014
    Very Useful
2  ×  three  =
