Electrical Calculator
Description
Selecting overload protection and wires for transformers involves number of rules that change with transformer size, type, and placement of the overload protection. This calculator helps determine the current values on both sides of the transformer, and estimates available short circuit current.
Productive
Quickly calculate; Power, Voltage, Current, and Power Factor. Estimate the maximum available short circuit current at transformer terminals.
Flexible
Enter values using mouse or keyboard in any sequence you like, current for a given power, or vice versa.
Easy to use
Does not require manual. All terms and definitions explained on screen. Built-in Typical Code multipliers. Built-in typical transformer impedance values.
Software:Electrical Calculator
Version:-
Developer:MC Group
Price:Free
Download:Please login first
Don't miss anything!
Powered by MailChimp
  1. baseemkhan04
    Jul 12, 2011
    veryy effective
  2. Edvard
    Jul 14, 2011
    Yes, it’s very handy tool for making quick calculations.
  3. MARLOU RABINA
    Nov 14, 2011
    VERY USEFUL
  4. ays10
    Mar 17, 2012
    thank’s a lot , keep on going up
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Fire Protection Measures
The measures to mitigate or lessen fire hazards are normally called “fire protection measures”. The National Fire Protection Association NFPA...
What happens when the wind doesn’t blow?
One of the questions most often asked about wind power is ‘what happens when the wind doesn’t blow’. In the...
Sudden pressure relay in oil-filled power transformer
Internal arcing in an oil-filled power transformer can instantly vaporize surrounding oil, generating gas pressures that can cause catastrophic failure,...
Close
