Calculate fault current
This MS Excel Spreadsheet represents an easy way to calculate fault current by entering few values in indicated fields. You will find sheet with very nice example already fulfilled. Before starting fault current calculation, you will have to choose between Step 1a and Step 1b which are explained below.
Available fault current spreadsheet
Step 1a
Insert available fault current ampere rating from your local Utility.
Step 1b
Insert the the kVA rating power factor (PF) and impedance  (Z) of the transformer is not required to continue. Note: When you insert the kVA rating  power factor and impedance you must select the voltage from the dropdown box Select Voltage & Phase before the value will be calculated.
Software:Fault Current Calculation (MS Excel Spreadsheet)
Version:7.1
Developer:John Sokolik
Price:Free
Fault Current Calculation Spreadsheet
30 Comments
  1. CONTROL ENGINEERING
    Oct 04, 2023
    Plz.can you send this excel software?Available Fault Current Calculation
  2. gebre
    Jun 27, 2023
    please we need this Excel should be free for African and Asian peoples.
  3. Carlo
    Apr 20, 2022
    Is there a way to unlock the spreadsheet so I can run calculations on 277/480V?
    • RockElectric
      Sep 15, 2022
      Just use one of the on line password breakers – Google is your friend !
  4. Dennis Moon
    Oct 25, 2021
    I would like to download various MS Excel Spreadsheets offered on the website. Do I have to be a member? If so, what type?
    …..thanks
  5. anup paudel
    May 10, 2021
    i use 11/04kv transformer but this sheet no option of this voltage level
  6. Abdullah
    Apr 23, 2021
    Can someone please explain the source of the conductor constant C? What does that signify? What is the unit? What is the equation?
    I know this has something to do with resistance/distance but can’t really relate how
  7. jorge salomon
    Oct 14, 2020
    very good tool for projects.
  8. FAEZ
    Jul 24, 2020
    Very good work.
    Yet could you make an option which allows you to input the cable data in mmsq and not in AWG (European Standards)?
    Thanks in advance.
  9. Charlie Booth
    Jul 24, 2020
    Thanks a lot, it’s a big help. you’re so kind.
  10. Sitarama Murthy Durvasula
    May 21, 2020
    Nice Information . Thanks
  11. GBENGA OYELEKE
    Mar 31, 2019
    The tools are most valuable materials that will empowered young and existing engineers to grow in their field of operations.
    Much useful, thanks.
  12. AMINU
    Jan 19, 2019
    I am an electrical engineer at the Federal College of Education Yola
    I work in the Electrical section of Works Department
    I really really enjoy your articles keep it up please.
  13. Rajendra Rathod
    Nov 16, 2017
    Thank you, sir
    good article
  14. Tikanand Dewoo
    May 18, 2017
    Thanks a lot Sir. Very useful and detailed sheet. Will surely be using this on many tasks and journey
  15. priyaranjan mohanty
    Nov 06, 2015
    Very nice and worth for learning!!
  16. Michael Furtak
    Aug 26, 2015
    Comprehensive short circuit analysis factors in both active and reactive parts of equipment impedance and contributions from multiple sources including motors and generators. Consider free Short Circuit Analytic software program at http://arcadvisor.com/short-circuit-software for your short circuit fault current calculations needs.
  17. Ricardo Reyes
    Jul 28, 2015
    Thank you very much, Interesting topics… Nevertheless, could you provide me a background for the medium voltage transformer ground fault system protection. In particular, design application and calculation of a right NGR for a Power Transformer, 12/14MVA, 13.8/4.16KV, delta-Y, 3ph, 60Hz.
  18. David A Engelhart
    Feb 16, 2015
    I found an error in this calculator prior to this version when I learned how to calculate longhand. I also got John to add the Utility Fault Current cell that is present in this version. This file is also available at MikeHolt.com in his free stuff where I got my copy to critique. The Electrical Plan Review PDF file is what taught me to calculate fault current by longhand. http://www.mikeholt.com/technical-calculations-formulas.php
    • Mahendra Mistry
      Mar 19, 2015
      David
      Can you provide information with examples on how to calculate fault levels the long hand method. Thanks.
  19. walter graham
    Jan 26, 2015
    this is a very good website!
  20. iacovos Charalambous
    Jun 30, 2014
    I work with Electricity Authority of Cyprus and i am the section head of High voltage cables.
    I really enjoy reading your articles. They are very good and very helpful.
    I am using your spread sheets for various calculations.
  21. gaitan
    Nov 23, 2013
    Great work!!
  22. S.M.Nazraton Nayeem
    Nov 22, 2013
    It’s a great work….
  23. Padlock01
    Jul 15, 2013
    Just a comment on available software please remember that especially on the african continent
    we use mm2 conductors as apposed to AWG so it would be nice to select either.
  24. mosesma
    Nov 29, 2012
    Thank you for the great work you have done.
  25. matbon
    Nov 07, 2012
    Very good work.
    Thanks in advance.
  26. neel151
    Sep 07, 2012
    Thank you very much. It is great to have such kind of facility to able to speed up your calculations.
  27. arun banerjee
    Jun 26, 2012
    Thanks a lot!
    Such kind of excel sheets are definitely useful to crosscheck the calculations.
  28. kalayil78
    Mar 24, 2012
    Hi ,
    Excellent work,
    But , can you pls update this with LV Earthing system (IT,TT,TN etc..) & Transformer windg method (Y,DYN,yn etccc). with out these the pgm is good enogh only for 3 phase fault which is not allways the design criteria of LV system.
    Thanks in advance
sixty three  ⁄    =  7
