Powerline Voltage Drop Calculation (MS Excel Spreadsheet)
Introduction
Standard Arctic BS6500
Cable Size
(mm2)
Single Phase
Volt Drop
mV/M/A
Current Capacity
2,51925
41232
Above figures for Voltage Drop are taken from BS7671 :2008 Table 4F3B (Appendix 4)
Above figures for current Capacity are taken from BS7671:2008 Table 4F3A (Appendix 4)
Total Volt Drop = Cable Length M x Current A x Volt Drop / Metre / Amp V/M/A
BS7671:2008, 525.1 – In the absence of any other consideration, under normal service conditions the voltage at the terminals of any fixed current-using equipment shall be greater than the lower limit corresponding to the product standard relevant to the equipment.
BS7671:2008, 525.2 – Where fixed current-using equipment is not the subject of a product standard the voltage at the terminals shall be such as not to impair the safe functioning of that equipment.
BS7671:2008, 525.3 – The above requirements are deemed to be satisfied if the voltage drop between the origin of the installation (usually the supply terminals) and a socket-outlet or the terminals of fixed current-using equipment does not exceed that stated in Appendix 12.
BS7671:2008, 525.4 – A greater voltage drop than stated in Table 12A (Appendix 12) may be accepted for a motor during starting periods and for other equipment with high inrush currents, provided that it is verified that the voltage variations are within the limits specified in the relevant product standard for the equipment or, in the absence of a product standard in accordance with the manufactures recommendations.
BS7671:2008 Table 12A (Appendix 12) – The voltage drop within each final circuit should not exceed 3% for lighting and 5% for other uses.
Standard POWERLINE Strings
Strings are available in 25. 50 or 100M lengths of 2-5 or 4mm2 3 core Cable with T drops every 5 or 10M
Software:Powerline Voltage Drop Calculation
Version:2.0
Developer:BLAKLEY Electrics
Price:
Downloads:Here 🔗 (Get Premium Membership) | Video Courses | Download Updates
  1. Ismet
    Jul 19, 2018
    i am looking for a voltage drop calculator and cable sizing spreadsheet for a 3 phase utility distribution line where i can input the loads at each pole of each customer and it can tell me for each branch of the distribution network what cable size to use and what is the voltage drop. i will use this for rural electrification of villages. Can you help please?
  2. Gary
    Mar 21, 2015
    Great site,
  3. tarekdia
    Jan 12, 2013
    please reload this page because it is messing
    https://electrical-engineering-portal.com/effective-substation-grounding-1
