NFPA 70E-2003
This Excel file combines arc flash equations from a proposal to NFPA 70E-2003 with simplified equations to calculate available fault current. This tool uses methods that have been shown to result in conservative estimates of fault current, which should result in conservative estimates of arc incident energy if appropriate arc fault clearing times are used.
An IEEE 1584 equation is used to calculate arcing fault current. That is the fault current value that is used to determine the clearing time of the overcurrent protective device ahead of the potential arc fault location. Electrical engineering should be consulted to obtain information on fault clearing times.
Arc flash calculation is not an exact science and caution is always necessary, including use of multiple alternate methods that are available to verify results and ensure the highest level of safety based on the best information available.
According to the NFPA 70E Technical Committee on Electrical Safety Requirements for Employee Workplaces, This proposal presents the best information available to date on arc fault hazards. Public review and comments are strongly encouraged. Recent testing has enabled development of improved equations for calculating the arc flash incident energy at the arc flash boundary. While the testing and development of methods is not complete this proposal contains methods that reflect significantly more laboratory data than the existing methods and will allow improved safety.
This calculator is for use only with systems operating at less than 1000 volts. If any doubts exist on use of this spreadsheet, or to perform a flash hazard analysis on systems operating at more than 1000 volts, consult with an electrical engineer or other knowledgeable person.
| Software: | Short Circuit And Arc Flash Calculator |
| Version: | - |
| Developer: | Hanford |
| Size: | 1.8MB |
| Price: | Free |
Don't miss anything!
diego bracamontes
I am studyng a master on electrical engineer, and the information shown very useful and interesant.
Edvard
Thanks Diego! Hope you found what you were looking for!
ANU SHREE
i need a software for Earthing…. could you suggest any?
Edvard
Maybe we’ll add some software for it in near future.
BR
bobdeck
I try to download an application but it says to login first. I login in but then cannot get back to the download page because I’m on another website you have directed me to. A nice Catch-22.
Edvard
Try now. There was some modifications in portal. Please let me know if you still have problems with downloading.
Eaton: New DC Switchgear Series for Photovoltaic Applications | EEP
[...] rated current and a maximum rated voltage of 1000V. If users also require overload and short-circuit protection in addition to the basic isolating function, circuit-breakers are available in three sizes with a [...]
