Size of Diesel GenSet
This spreadsheet intend to calculate size of needed diesel generator according to the following input parameters:
- System Voltage ( P-P ) in Volts
- System Voltage ( P-N ) in Volts
- Future Load Expansion in %
- Average Intermittent Use of Equipment (0.7 To 1.0)
You are about to enter following information for each consumer you have in your consumption calculation:
- Equipment (name)
- Load Type (linear, non-linear or motor)
- Supply (1ph or 3ph)
- Qty (num.)
- Load (in kW)
- Starting P.F
- Running P.F
- Diversity Factor
- Motor Starter (Dol, Y-D, auto-transformer, soft starter or frequency converter)
Calculated results consist of:
- Size of Diesel GenSet for linear, Non-linear Load
- Size of Diesel GenSet for motor load
- Diesel GenSet Efficiency
- UPL (unit per liter) of Diesel GenSet
- Unit power cost of Diesel GenSet
- Approximate fuel consumption
| Software: | Calculate Size of Diesel Generator (MS Excel Spreadsheet) |
| Version: | 22.08.2012 |
| Developer: | Jignesh Parmar |
| Size: | 138 Kb |
| Price: | Free |
hi, its very interesting, but can i get the password to open the protect spreadsheet?
thankyou
It is helpful to me as an electrical engineer
Cannot be downloaded.
I’m happy to have professional discussion related to Power
Want to know the standard / reference used for DG sizing calculation and criteria to be followed.
Hi guys.
I am thinking to star a 3 phase motor 75 kw, 460 VAC with a Diesel generator (144 HP rated ), 460 VAC using a soft starter.
Sombody can help me if this is posible?
hey guys
how can i calculate the Diversity Factor in a utility with 3 3ph motors that are working simultaneously?
Better late than never.
The 3 mortors are working simultaneously, so the diversity factor Kd = 1 (*)
If ypu want to estimate the energy consumption per day, you have to use loading factor or utilization factor generaly = 0.80. But if you know the power absorbed by the machine driven by the electric motor, then, the utilization factor Ku = Machine power/Nominal motor power.
The global factor Kg = KdxKu.
If Ku = 0.8, then Kg = 1×0.8 = 0.8.
If the unit nominal power of your motors is Pn = 22 kW, the total power absorbed is : 3×0.8x 22 = 52.8 kW.
If your 3 motors work 8 hours per day, then the energy consumed per day is : E = NxKgxPnxt = 3×0.80x22x8 = 422.4 kWh.
Calculations shown for DG sizing is having minor errors, starting KVA is multiplied twice.
Hey guys
now I have 1200 ekw generator with fuel consumption 333 l/hr and I need to calculate the efficiency of that generator set
is the efficiency subjected to the following equation ?:
Qin =Wout+Qrej
Then ᶮ ( efficiency ) = Wout/ Qin .. Wout = 1200 Kw
Where Qin = m°f *Cvf
Cvf ( for diesel) = 46000000 j/kg
ρ= 850 Kg/m³
But the result was not good
ᶮ = about 33.17 %
kindly advise me
can anyone please send the detailed calculations and formulas used in this spreadsheet?…it would be really helpful
What is the difference between Average Intermittent Use and Diversity Factor ??
Good Job
How do I add the Air Conditioning units? Are they linear or non? I only know the ton value of each.
And, What is the correct connection for single phase ACs and lights? Is it Y-D?
I also have a three phase 60 HP submersible pump that sucks 150 Amps on each phase to start and then goes to 90 Amps to run. Your sheet says that the full load Amps is 38 while I see on the DG display 90 Amps on each of the three phases.
What about considering non linear loads in %age of total load in sizing? The limits of such loads govern sizing if exceeded. Any international standards talks about this in sizing the Genset? How it will be applied in the calculation?
Consider a case where EDG is to be started on to a distribution transformer.How to size the DG set then?
we have total load in kw .how do we arrive at genset capacity??/
How can we conduct the load test of DG set at site?
Engine overload is 10% only not 130 to 150%.
It is depend for Standby application or Prime or base load .
It is better to check and alternator efficiency is about 93 to 96
how to calculate the required daily / monthly fuel tank of generator?
Hooh, sounds very interesting, but I wouldn’t know really. I guess that eash manufacturer has its own manual or guide you should follow.
Anyway, your question’s answer depends on how many hours generator will work.
Edvard, Can I get a password to unprotect the spreadsheet?
Wonder that the starting power factor of the motor assumed to be as 0.8 is correct.Normally the value may be 0.2-0.3.The pf at 80% of speed during starting may be 0.6.Moreover the highest rated motor starting with base load and as well as voltage drop need to be considered for DG sizing.
Your feedback please.
I’m not able to download this item. Please guide me.
Thanks a lot
Link works quite well, I double checked. Maybe you’re having problems with Box.com on your side?
I’m not able to download this. I also tried to download other sheets some time back but faced the same problem.
Please suggest.
Real useful.. Double checked my calcs =)
Thanks a lot
Sir,
How accurate the spreed sheet is? this have been tested on site?
Thanks!
