3-phase systems and 1-phase
Calculation of touch voltage and ground current can be performed on single-phase or three-phase systems.
Calculation of Touch Voltage and Ground Current
According to the inputs for the three-phase system:
Line-to-Neutral Volts (Vn), Line 1 Calculated Load (A1), Line 2 Calculated Load (A2), Line 3 Calculated Load (A3), Service Neutral Impedance Z1, and Ground Resistance (3-point method) R, the spreadsheet will calculate the following parameters:
  1. The resistance of Each Phase
  2. The resistance of neutral/Ground
  3. Neutral Current and Load
  4. Touch Voltage for the Metal part to Earth
  5. Body Resistance and Body Current
For single-phase, systems input parameters are: Circuit voltage and ampere, load, ground, electrode, and body resistance.
Software:Calculation of Touch Voltage and Ground Current
Version:22.08.2012 New
Developer:Jignesh Parmar
Price:Free
Touch Voltage and Ground Current Calculation
16 Comments
  1. [email protected]
    May 17, 2023
    Am I able to free download or subscribe the excel sheet for step and touch voltage and ground current calculations as the excel sheet shown above.
  2. Haytham Alloush
    Oct 30, 2021
    Hi
    Please advise if the step & touch voltage and GPR should be calculated for LV systems as street lighting poles ,or step and touch voltage is required to be calculated Ac substations /HV as per IEEE 80 ?
  3. zayed
    Jul 11, 2021
    why Ground Potential Rise for 24VDC solar system minimal?
  4. JAMES K TETTEH
    Mar 10, 2021
    I am an electrical engineer and I’d like to express my great thanks to managers of this web site and its all writers. Meanwhile, I want to add one general comment. Normally in spreed sheets, the american units (mile, foot square, AWG and…) are being used. Please develop equivalent METRIC sheets too.
    Regards:
  5. Enkali jafet Nyanyukweni
    Sep 07, 2019
    I am struggling to calculate volt drop on three phase , touch volt I need a help
  6. Gafar jimoh tosin
    Aug 31, 2019
    The touch calculation is very useful, thanks.
  7. Gafar jimoh tosin
    Aug 31, 2019
  8. Vilas Pathak
    Aug 31, 2019
    Good & Helpful Information.
  9. VIJAY KUMAR BHASKAR
    Aug 31, 2019
    Thanks for enrolling me . It is really useful website
  10. Carlos
    Nov 25, 2018
    I’m a Relay Technician and I’m fascinated by all this kind of technical information. Thank you very much!!
  11. David Bridglal
    Jul 18, 2018
    Put in Constant Voltage Transformers.
  12. Khaled Ellithy
    Jan 25, 2018
    Excellent
  13. Er DEBASISH PATTANAIK
    Dec 26, 2014
    Dear Friends,
    Recently we have installed a 500kwp solar power plant in our state .It is a on grid system,about 25 nos of solar inverters have been installed in a area of around 1.5 km radius in different building.Here we found that the 20 kwp inverters at last building is developing over and under voltage and going failure.So pls anybody suggest what could be the reason for this and available solution.Thanks
    • Harnam Trehin
      Jun 09, 2015
      Please send me your single line and distances of each inverter from each other and from the load centre. Also please tell me what is the switching frequency of your IGBTs. Log onto our website we can help you if you still have the problem with the last inverter.
      Thanks,
  14. saeid
    Feb 22, 2014
    in the name of god
    tnx a lot
    helpful
  15. farajzadeh
    Sep 07, 2013
    Regards:
    Farajzadeh
