Voltage Drop Calculator
Feeder Sizer
This application could also be called “Feeder Sizer” as it provides all information required to size feeders. Colour coding of maximum allowable ampacity values – according to CEC or NEC – helps choose the correct wire size. Voltage drop values are updated on the fly, conduit size is shown and if you size the feeder for a motor, Full Load Ampers for typical motors are built-in.
With rising cost of electricity you may find the “Feeder Efficiency Tip” useful. It informs when it may be beneficial to increase wire size above the minimum required by code.
Productive
Helps select proper wire and conduit size. Estimates full load current of motors based on Horse Power rating.
Flexible
Enter values in any sequence. Has built-in NEC & CEC wire ampacity tables for US and Canada. Prints results.
Easy to use
All terms and definitions are explained on screen. No manual required.
New Feature
Calculates the cost of energy lost during feeder operation.
Software:Voltage Drop Calculator
Version:-
Developer:MC Group
Price:Shareware, 30USD
Download:Please login first
Don't miss anything!
Powered by MailChimp
  1. [...] dramatic:Short circuit disturbs the system environment around the fault point by causing a sudden drop in voltage,it requires a part of the system (often a large part) to be disconnected through the operation of [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
How to select AC converter for VSD?
Altough manufacturers’ catalogues try to make it easy as possible, there are many variables associated with the selection and rating...
How reactive power is helpful to maintain a system healthy
We always in practice to reduce reactive power to improve system efficiency. This are acceptable at some level, if system...
Who was James Prescott Joule?
James Prescott Joule was born on Christmas Eve 1818 into a wealthy Salford brewing family. A sickly child, he was...
Close
