Home / Technical Articles / Electrical Thumb Rules You MUST Follow (1)
Estimated Study Time: 18 minutes
This technical article deals with the electrical thumb rules related to cable capacity, current capacity of equipment, earthing resistance, minimum bending radius of a cable, insulation resistance, transformer and lightning arrestor parameters, diesel generator, and current transformer (CT).
Electrical Thumb Rules You MUST Follow (Part 1)
Electrical Thumb Rules For:
Cable Capacity
The component that ultimately affects a cable’s current carrying capability is the maximum operational temperature that the cable can withstand throughout its lifespan without incurring damage or degeneration. The heat produced in the cable arises from (a) ohmic losses in the conductor, (b) dielectric losses in the insulating medium, and (c) sheath and intersheath losses.
The created heat is emitted to the environment. The current capacity is dependent upon the conductivity of the surrounding medium, resulting in varying ratings for the same cable based on whether it is buried or exposed.
1. For Cu Wire Current Capacity (Up to 30 Sq.mm) = 6× Size of Wire in mm2
Example:
  • For 2.5mm2 = 6 × 2.5 = 15 Amp,
  • For 1mm2 = 6 × 1 = 6 Amp,
  • For 1.5mm2 = 6 × 1.5 = 9 Amp
2. For Cable Current Capacity = 4× Size of Cable in mm2
Example: For 2.5mm2 = 4 × 2.5 = 9 Amp.
3. Nomenclature for cable Rating = Uo / U
where:
  • Uo = Phase-Ground Voltage,
  • U = Phase-Phase Voltage,
  • Um = Highest Permissible Voltage
Go to Content ↑
Current Capacity of Electric Motor
The torque required by the motor is the criterion for determining the appropriate drive size. Horsepower ratings (HP), although provided by drive manufacturers as a reference for the maximum motor size in most applications, lack precision.
For applications requiring continuous torque, the suitable drive may be considered “oversized” in relation to the motor. Typically, general-purpose constant torque drives have an overload current capacity of around 150% for one minute, relative to nominal output.
Should an application surpass these limitations, a bigger drive must be specified.
  • 1-Phase Motor draws Current = 7 Amp per HP.
  • 3-Phase Motor draws Current = 1.25 Amp per HP.
  • Full Load Current of 3 Phase Motor = HP × 1.5
  • Full Load Current of 1 Phase Motor = HP × 6
  • No Load Current of 3 Phase Motor = 30% of FLC
  • KW Rating of Motor = HP × 0.75
  • Full Load Current of equipment = 1.39 × KVA (for 3-Phase 415 Volt)
  • Full Load Current of equipment = 1.74 × kW (for 3-Phase 415 Volt)
Go to Content ↑
Earthing Resistance
Historically, an earthing system characterized by low overall earth resistance was thought to be safe. Nonetheless, a direct correlation between the resistance of the earthing system (such as 1Ω or 10Ω) and the likelihood of a fatality occurring in any specific scenario does not exist.
A comprehensive study that considers every relevant factor and provides a realistic evaluation of the risks is thus essential.
The objective of earthing system design is to achieve sufficient resilience while balancing cost, practicality, and risk management. Numerous risk scenarios, such as those including both touch and step voltage hazards frequently require analysis about the interactions among specific scenarios, including trade-offs, as well as the influence of different design configurations on the overall risk profile of the site and system.
  • Earthing Resistance for Single Pit = 5Ω, Earthing Grid = 0.5Ω
  • As per NEC 1985 Earthing Resistance should be < 5Ω.
  • Voltage between Neutral and Earth ≤ 2 Volt
  • Resistance between Neutral and Earth ≤ 1Ω
  • Creepage Distance = 18 to 22mm/kV (Moderate Polluted Air) or
  • Creepage Distance = 25 to 33mm/kV (Highly Polluted Air)
The basic understanding of an earthing protection system (diagram and definitions)
Go to Content ↑
Minimum Bending Radius for Cables
Training refers to the installment of cable when it is not subjected to tension. Bending refers to the installment of cable when subjected to tension. The objective of cable installation is to minimize mechanical stresses to preserve the cable’s physical and electrical properties during its predicted service life.
Bends in conductors, multi-conductor cables, or conductor assemblies must be handled in such way that the cable will not be damaged.
A non-shielded cable can withstand a more sharp bend than a shielded cable. This is particularly applicable to cables with helically applied metallic shielding tapes, which may split or buckle and penetrate the insulation when subjected to excessive bending. Bear in mind that offsets are deviations.
The issue is made worse by the presence of jackets that obscure the damage on most tapes. The extruded polymers used for insulating shields initially provide adequate conductivity and coverage to meet acceptance tests, but then fail prematurely due to corona at the shield/insulation interface.
  • Minimum Bending Radius for LT Power Cable = 12 × Dia of Cable.
  • Minimum Bending Radius for HT Power Cable = 20 × Dia of Cable.
  • Minimum Bending Radius for Control Cable = 10 × Dia of Cable.
Handbook on EHV overhead lines and underground cables
Go to Content ↑
Insulation Resistance
When any electrical equipment is new, the electrical insulation should be in the best possible state. Moreover, manufacturers of cables, wires, electric motors, transformers, and similar equipment have consistently improved their insulation for industrial applications. Nonetheless, even today, insulation is susceptible to numerous factors that might lead to its failure, including mechanical damage, vibration, extreme temperatures, pollutants such as dirt and grease, corrosive vapors, process-related moisture, or simply humidity on a humid day.
These adversaries of insulation operate at varying extents over time, compounded by existing electrical strains. As pinholes or cracks form, moisture and contaminants infiltrate the insulation surfaces, creating a low-resistance pathway for leakage current.
Once initiated, the many adversaries tend to assist one another, allowing excessive current to pass through the insulator. Occasionally, the decline in insulating resistance occurs abruptly, such as in instances of equipment inundation. Typically, it declines gradually, providing ample warning when monitored regularly. Such inspections enable scheduled maintenance prior to operational failure.
In the absence of inspections, a motor with weak insulation may provide a risk of electric shock when energized and is also susceptible to burnout. What was once effective insulation has transformed into a partial conductor.
  • Insulation Resistance Value for Rotating Machine = (kV+1) MΩ.
  • Insulation Resistance Value for Motor (IS 732) = ((20 × Voltage (L-L)) / (1000 + (2 × kW)).
  • Insulation Resistance Value for Equipment (<1KV) = Minimum 1 MΩ.
  • Insulation Resistance Value for Equipment (>1KV) = kV 1 MΩ per 1kV.
  • Insulation Resistance Value for Panel = 2 × KV rating of the panel.
  • Min Insulation Resistance Value (Domestic) = 50 MΩ / No of Points. (All Electrical Points with Electrical fitting & Plugs). Should be less than 0.5 MΩ
  • Min Insulation Resistance Value (Commercial) = 100 MΩ / No of Points. (All Electrical Points without fitting & Plugs).Should be less than 0.5 MΩ.
  • Test Voltage (A.C) for Meggering = (2 × Name Plate Voltage) +1000
  • Test Voltage (D.C) for Meggering = (2 × Name Plate Voltage).
  • Submersible Pump Take 0.4 KWH of extra Energy at 1 meter drop of Water.
Further Study – Measurement of insulation resistance (IR)
Measurement of insulation resistance (IR) – Part 2
Go to Content ↑
Lightning Arrestor
Lightning arresters are engineered to restrict line-to-ground voltage during lightning strikes or other extreme transient voltage situations. Certain earlier gap-type lightning arresters unintentionally short-circuited the line or equipment, resulting in the circuit breaker tripping. The breaker would thereafter reclose once the transient overvoltage condition had gone. The lightning arrester protects nearby equipment against high-voltage transient events.
For instance, consider an 11 kV lightning arrester installed on a 7.2 kV line to neutral system. The lightning arrester will operate if the line-to-neutral voltage above roughly 11 kV. Electrical equipment connected to this distribution system might have a flashover rating of 90 kV.
Consequently, the arrester limited the high-voltage transient, so preventing flashover or insulation breakdown in the electrical equipment.
Arrestor have two ratings:
  1. MCOV = Max. Continuous Line to Ground Operating Voltage
  2. Duty Cycle Voltage  (Duty Cycle Voltage > MCOV).
Design study for 33/11 kV substation, distribution and protection in the city of Kenya
Go to Content ↑
Transformer
Transformers operate through the integration of two physical laws. Physical law #1 asserts that a voltage is generated in any conductor subjected to a varying magnetic field. Physical law #2 asserts that an electric current passing a conductor generates a magnetic field. Transformers integrate these concepts by employing two wire coils and changing voltage source. The current in one coil of the transformer induces a voltage in the coil on the opposite side.
The two coils are interconnected through the magnetic field.
This notion is crucial as the entire electric power system relies on these interactions. Upon close examination, the voltage on one side of a transformer is directly proportional to the turns ratio, whereas the current on the opposite side is inversely proportional to the turns ratio.
Figure 1 – Transformer windings
The transformer seen in Figure 1 has a turns ratio of 2:1. A transformer with a 2:1 turns ratio, as depicted in Figure 4-4, will produce 120 Vac at 2 amps on its secondary winding (right side) when 240 Vac at 1 amp is connected to its primary winding (left side), as illustrated in Figure 2.
Figure 2 – Transformer turn ratio
Note: Power is 240 watts on both sides (i.e., voltage multiplied by current). As previously mentioned, increasing the voltage, such as in transmission lines, reduces the current and hence diminishes system losses dramatically.
  • Current Rating of Transformer = kVA × 1.4
  • Short Circuit Current of T.C /Generator = Current Rating / % Impedance
  • No Load Current of Transformer ≤ 2% of Transformer Rated current
  • Capacitor Current (Ic) = kVAR / 1.732 × Volt (Phase-Phase)
  • Typically the local utility provides transformers rated up to 500 kVA For maximum connected load of 99 kW,
  • Typically the local utility provides transformers rated up to 1250 kVA For maximum connected load of 150 kW.
  • The diversity they would apply to apartments is around 60%
  • Maximum HT (11kV) connected load will be around 4.5 MVA per circuit.
  • 4 No. earth pits per transformer (2 No. for body and 2 No. for neutral earthing),
  • Clearances, approx.1000 mm around TC allow for transformer movement for replacement.
Contract drawings for a power transformer – The checklist you should always follow
Go to Content ↑
Diesel Generator
Generators may be classified as synchronous or asynchronous. Asynchronous generators are sometimes known as induction generators. The construction is fundamentally identical to that of an induction motor. It features a squirrel-cage rotor and a wrapped stator. An induction generator is a motor operated over its specified synchronous speed, hence producing electricity. It will function as a motor while operating below synchronous speed.
The induction generator lacks an exciter and must function in conjunction with the utility or an alternative source. The induction generator requires VARs from an external source to produce power. The induction generator functions at a slip frequency, thereby synchronizing its output frequency with that of the utility.
An induction generator is commonly selected for cogeneration system designs, where it functions simultaneously with the utility grid. This generator type presents specific advantages compared to a synchronous generator. Voltage and frequency are regulated by the utility; therefore, voltage and frequency regulators are unnecessary.
The generator’s construction ensures excellent reliability and minimal maintenance. A minimum of protective relays and controls is mandated. The primary drawbacks are its requirement for VARs from the system and its inability to function as a standby or emergency generator.
Nonetheless, synchronous generators are the most used. Their production is dictated by their field and governor controls. Changing the current in the DC field windings regulates the voltage output. The frequency is regulated by the rotational speed. The torque produced on the generator shaft by the driving engine regulates the power output.
The synchronous generator provides accurate regulation of the electricity it can produce. In cogeneration applications, it can enhance the system’s power factor.
  • Diesel Generator Set Produces = 3.87 Units (kWh) in 1 Litter of Diesel.
  • Requirement Area of Diesel Generator = for 25 kW to 48 kW = 56 m2, 100KW = 65 m2.
  • DG less than or equal to 1000 kVA must be in a canopy.
  • DG greater 1000 kVA can either be in a canopy or skid mounted in an acoustically treated room
  • DG noise levels to be less than 75 dBA at 1 meter.
  • DG fuel storage tanks should be a maximum of 990 Litter per unit. Storage tanks above this level will trigger more stringent explosion protection provision.
Spreadsheet to Calculate Short Circuit Capacity of Diesel Generator Synchronizing Panel
Go to Content ↑
Current Transformer
The primary issue is that the CT core be appropriately dimensioned to fulfill the burden requirements. The burden covers both the associated metering burden and the lead burden. The metering class current transformer is designated with an accuracy rating corresponding to each standard burden for which it is were eligible. An illustration presented in IEEE C57.13 is 0.3 B-0.1 and B-0.2, 0.6 B-0.5.
The numeral following the letter B denotes the standard impedance in Ohms with a power factor of 0.9. The values 0.3 and 0.6 denote the accuracy class.
Protection class CT is often sufficiently precise for operating a range of indication equipment, while it may be inadequate for revenue class summing energy metering. A drawback of employing protection class CT for indication is its capacity to handle currents above 100A, which may exceed the thermal tolerance of sensitive metering equipment. In such instances, the standard practice is to implement an interposing auxiliary transformer, configured in a star/star connection.
The auxiliary transformer is designed to saturate at currents exceeding several tens of amperes. When selecting metering or auxiliary current transformers, the design burden must be accurately aligned with the actual connected burden.
Utilizing a connection with a lower burden than the design burden of the current transformer will let greater currents to pass through the metering apparatus before saturation occurs.
Nomenclature of CT:
  • Ratio: input / output current ratio
  • Burden (VA): total burden including pilot wires. (2.5, 5, 10, 15 and 30VA.)
  • Class: Accuracy required for operation (Metering: 0.2, 0.5, 1 or 3, Protection: 5, 10, 15, 20, 30).
Accuracy Limit Factor:
  • Nomenclature of CT: Ratio, VA Burden, Accuracy Class, Accuracy Limit Factor.
  • Example: 1600/5, 15 VA 5P10  (Ratio: 1600/5, Burden: 15VA, Accuracy Class: 5P, ALF: 10)
  • As per IEEE Metering CT: 0.3B0.1 rated Metering CT is accu­rate to 0.3 percent if the connected secondary burden if imped­ance does not exceed 0.1 ohms.
  • As per IEEE Relaying (Protection) CT: 2.5C100 Relaying CT is accurate within 2.5 percent if the secondary burden is less than 1.0 ohm (100 volts/100A).
IEC and NEMA/IEEE ratings of current transformers (CTs) in medium voltage applications
Go to Content ↑
Quick Electrical Calculation
1 HP = 0.746 kWStar Connection
1 kW = 1.36 HPLine Voltage = √3 Phase Voltage
1 Watt = 0.846 Kla/HrLine Current = Phase Current
1Watt = 3.41 BTU/HrDelta Connection
1 kWh = 3.6 MJLine Voltage = Phase Voltage
1 Cal = 4.186 JLine Current = √3 Phase Current
1 Tone = 3530 BTU
85 Sq.ft Floor Area = 1200 BTU
1 Kcal = 4186 Joule
1 kWh = 860 Kcal
1 Cal = 4.183 Joule
Go to Content ↑
Jignesh Parmar - Author at EEP-Electrical Engineering Portal
Jignesh Parmar
Electrical Middle management professional having more than 22 years rich and dynamic experience in Project Execution / Project Management / Designing / Maintenance diversifies from Electrical Power Transmission (400KV/220KV/66KV)- Distribution(11KV/220V) to Lifts-HVAC-Ventilation-Fire Fighting-Fire Alarm-Lifts-CCTV-Stack Parking Works (High Rise Buildings, Townships, Shopping Complex, Commercial Complex, School, Temple).
Profile: Jignesh Parmar
129 Comments
  1. Kothapalli KrishnaRao
    Jan 11, 2026
    Really appreciating many electrical professional in various domains of working .
    So i am expressing my heartily thanks for your effort to bring in front of real electrical world.
    If there any possibility , please give description of various control circuits of ACB, Motors Starters.
  2. DIPAYAN BHATTACHARYA
    Dec 12, 2024
    any thumb rule to follow for finding and solving issues at wiring and ferrules inside 11KV, 33 KV VCB, inside power substations? the DC and AC connections and thheir checkings
  3. PP DEY
    Jul 18, 2023
    THANKS FOR SHARING THE THUMB RULES
    • Janaki Prasad
      Dec 08, 2023
      Dear parmar ji,
      You are a great person, of Modi vision, make in India, you are making our indian technicals lerning strong.
      Thanks for best effort.
  4. Paulson John P.
    Jun 23, 2023
    useful for engineers those who works in projects
  5. MK Prakash
    Jan 20, 2023
    Perfect
  6. v prashanth
    Dec 03, 2022
    NICE AND PRACTICALLY APPLICABLE METHODS INVOLVED ….THANKS
  7. ABUL FAJAL
    Nov 08, 2022
    i learned many things by your post. thank you .
  8. RAJESH CHAUHA N
    Jun 16, 2022
    Dear sir,
    how to make calculate , cable size 3cx70 sqmm copper pvc insulated double gi strip armoured,
    pl clear this point the conductivity of armour shall not less then 75% of the conductivity of larg core
    how many copper strip use for the conductivity maintain.
  9. Bipin Kumar Singh
    Feb 14, 2022
    What would be current carring capacity of cable in 3phase system?
  10. Satish Wagh
    Feb 01, 2022
    Very good info. for all engineers
  11. Hitendra Marge
    Dec 06, 2021
    Dear sir , need overload current carrying capacity for MV cable with trefoil and flat touching condition with different hours.
    Generally 1 /2/3/4/6/8/10/12/24 hour run with 60% / 75%/90% & 30% overload condition with respectively above mentioned time durations so please how can calculate in easy format.
  12. V Anguchamy
    Nov 18, 2021
    Need Cable current carrying capacity for 3 Phase Cable
  13. Shah
    Jan 18, 2021
    can we use 2 x 16sq.mm x 4core and 1 x 10sq.mm x 4core power cable instead of 1 x 35sq.mm x 4core cable for the connectivity of Diesel Genset (60 KVA) to ATS panel 20 feet apart.
    Please advice…
    • ozigi
      Jan 20, 2021
      2x16mm2 4-core cable which is 2 run of 16mm2 4-core cable is more than enough to connect 60kVA generator to ATS panel
      giving that the generator current = 86.6A
      • SHIVAPRAKASH
        Mar 18, 2021
        We Have a powerloom factory…with each one has 330 watts 3 phase induction motor voltage -220 freq-50hz
        we have used 4 sq mm for mainline and 2.5sqmm for each motor for 12 motors.
        Can We Connect that same 4 sq.mm for another 12 motors or we have to add 4 sq mm wire…Help me with your knowledge
    • Prem Singh
      Mar 05, 2021
      YES.
      We bundled conductors instead of single conductors for ac transmission to reduce skin effect.
      If you provide two cables 4Cx35 Sq mm for one cable 4Cx35 Sq. mm then the system is sufficient and addition of 4Cx10 Sq mm will make it extra strong.
    • Shahzad
      Dec 12, 2021
      Yes you can
  14. Sudhakar
    Dec 11, 2020
    Hi Sir,
    In a substation we use different connectors, like, bus support, couplers, body & cap connector etc, I would like to know what each component is rated for with respect to ampacity. How can we calculate that, is there a way to do that.
  15. Chandraprakash G
    Nov 29, 2020
    Excellent and neat write up, keep the great work !!
  16. murali nagarajan
    Nov 19, 2020
    3phase 40A energy meter 17Nos in one apparetment.
    How much amps switch rating and transformer is required?
  17. saranraj.M
    Sep 17, 2020
    Typically the local utility provides transformers rated up to 1250kVA For maximum connected load of 150kW.
    Power factor*KVA=KW
    0.8*1250=1000KW
    But here answer is 150KW
    How it will calculate?
  18. Hemant Samal
    Jul 16, 2020
    Sir, one of my client wants to take connection having his required load 70 KW. In fact I have maximum feeder capacity in the existing panel 100 AMP TPN,MCCB-16 KA. Please suggest me the Feeder specification, so that I can install it in my panel in the spare box. also please eleborate the formula to select.
  19. Rama Sinha Adhikari
    Nov 26, 2019
    Thank you sir. This is very needful to us.
  20. Raj kumar
    Oct 27, 2019
    Sir,
    I need to know the load calculations of
    2core 1sqmm al ar cable = Amps
    1sqmm cu cable = Amps
  21. Subhro
    Jul 24, 2019
    Tor electrical calculation should we take 1HP= 735.5W or 746W
    • Anup Kumar
      Oct 13, 2020
      1HP=746W
  22. C P
    Jul 15, 2019
    Dear sir
    Twin core flat aluminium pvc insulated cable when we are supply current one core than earthing second core why ?
  23. Abhishek Robinson
    Jul 09, 2019
    Dear sir
    I need your expertise ON TRIPOING OF 220KV EHV transmission line, during lightening.
    Need your help. Can I have your contact number please.
  24. udeerna kV
    Jul 08, 2019
    Very very nice ..very very useful informations &Calculations..thank u very much
  25. V PRASHANTH
    Jul 04, 2019
    For 4Cx 6sqmm cu at cable, you can go with 4Cx 25 sqmm Al AR XLPE cable. And for 3Cx4sqmm you go with 16sqmm if the length is less than 80 to 100mts.
  26. Nanhey lal chauhan
    Jan 13, 2019
    load calculation of3.5*300 sq mm al. cable
  27. Pramod
    Dec 31, 2018
    For single core house wiring to 1.5 sq. Mm. How much current take ?
  28. N Satyanarayana
    Nov 16, 2018
    2800KW, 12Amps 1 phase AC load and distance between incoming supply source to load point is 1500mtr. Cable laid in under ground and HDPE pipe. now can you please suggest cable size and voltage drop calculation
  29. avinash lahane
    Oct 31, 2018
    How to select ct burden when current 1000A and voltage 433 v for metering and capacitor panel realy operating purpose.
    Avinash Lahane
    M-9225305991
  30. YECHURI SAI AKHIL KUMAR
    Oct 14, 2018
    i want to replace 4c*6sqmm copper armed cable with aluminium armed cable can u suggest the thickness of aluminium cable .and also i want to replace 3c*4sq mm copper with aluminium can u please suggest the thicknesses of aluminium cable
  31. Samrat sinh Jhala
    Sep 13, 2018
    How to calculate the full load current of a 3 phase submersible,440V?
  32. somasundaram n
    Sep 04, 2018
    Sir
    What are the details of motor installed in washing machine to be found out to select strength of wire ie. 2.5 s.qm or 4.5 sq.m or 1.5 sq.m wire to give power supply?
    whether 15 amp.plug and socket can be powered with 1.5 sq.m flexible wire already given for 5 amp socket in the boar or more than 1.5 sq. metre strength wire to be used?
    your kind reply will be useful for me.
    Somasundaram N
  33. Sushil Kumar
    Aug 03, 2018
    Dear Sir
    Can We use 4mmx4core copper armoured cable for 10HP motor coupled with 60LPM hyraulic pump. Application is for chopping/cutting of scrap sheet after blanking
    • Badshah
      Jun 26, 2019
      pls see size of cable. i think it should be higher. you can follow chart for “current vs size of cable”. also different chart for Cu and Al is there
  34. Nilesh
    Jul 20, 2018
    Can I use 25x2x0.75sqmm twisted,shielded cable instead of 50×0.75sqmm shielded cable?
    Application :- I need to transmit 230VAC power from stepper drives to motor.
  35. SIVAKUMAR G K
    Jun 06, 2018
    SIR,
    FOR 100 KW SOLAR PLANT CAN I USE 4C*70 SQ.MM(COPPER) TELL ME ITS ENOUGH.FROM ACDB TO EXISTING PANEL
  36. Gnanaguru
    May 16, 2018
    Hi fella,
    I came across this website and got lost in wire Vs cable hurricane :) Later in comments I’ve seen cables AKA “bunch of wires” explanation. Where I got stuck is, according to your statement
    “Cable Current Capacity = 4X Size of Cable in Sq.mm, Ex. For 6 Sq.mm = 4×6= 24 Amp.”
    Yet in the mean time, I’ve witnessed mine sq.mm wire stood against the current capacity of around 28A for nearly 30minutes!!! Its details are Unsheated,Copper made,No. of wires/Wire dia metre=85/.30. So I’m expecting 6xSize in sq.mm instead of 4XSize in sq.mm. So I want you to clearly tell me what does wire Vs cable means?
  37. ahmad ayaz
    May 12, 2018
    its really helpful i am very thank full to you for your this kind of act.
  38. ansari
    Mar 30, 2018
    hi
    finaly i found nice web site to improve my knowledge. i have to know if i communicates RS485 data with 1.5sq mm 2 core twisted wire without sheld and run the wire 60 mtrs what will happen.
    pls advice
  39. vignesh
    Mar 24, 2018
    Here we using the load 3.6Amps and the same we are using the wire 2.5Sq.mm.If it is ok or we need to change.
  40. Aniesh Mathew
    Mar 18, 2018
    We have the Main Panel MCCB of 400A 4P and the load is 120kVA. The client has provided raw power using 4 core 95Sqmm Aluminum Armoured cable. Please let me know whether the raw power cable is fine for our load?
    Also what is the load 95sqmm can take?
    • Arvind YADAV
      May 12, 2018
      According to load the cable size is good enough, and the cable can carry up to 220A current which means 120Kw or 140KVA
  41. H M Khyruzzaman
    Feb 03, 2018
    Thanks. Very effective information.
    Please give me a clear idea how can I find the contactor rating & over load relay rating for Star-delta Starter. Give me this example for 30kW motor.
  42. Dilip wade
    Dec 30, 2017
    Very useful make PDF and publish for download
  43. Vijay Kumar Job
    Dec 18, 2017
    Please correct 2.5×4 = 9Amps to = 10Amps.
    in cable current capacity thumb rule.
  44. Bello Babayo
    Dec 12, 2017
    Intresting and educative forum for power engineers
  45. Benson Barasa
    Aug 06, 2017
    This forum is indeed amazing quite educative.
    Keep up the good work.
  46. pn iyengar
    Jul 31, 2017
    Sir, How do the GEB pole lines are identified for phase , neutral and earthing. Reason for my asking is all the lines ( Either 3 or 5 for single and 3 phase ) are same and there is no distinction. Recently in our street light pole tuble light connection, an electricians has given some wrong connection by joining 2 wires either in phase or in neutral. Because of this many of our street people have lost TV, Fridge, AC, Digital wall clock etc. The GEB officials said that Munipal contractor has done the mistake while rectifying the defect in the pole street light. This is the reason why want to know for easy identification of these Phase, Neutral and Earthing wires of GEB Pole. pls. explain with sketch or drawing for easy understanding.
  47. Joseph Puduvala
    Jul 02, 2017
    Dear Sir,
    Would you please advise how can I connect 2 numbers of single phase 3000VA 230V 50 HZ UPS
    in Parallel for redundancy… Appreciate your early response
    Thanks and regards
    Joseph Puduvala
    • vinay kumar
      Nov 15, 2017
      These single phase ups can be connect in parallel only when there Output voltage and frequency are same. so please communicate with service provider to set voltage and frequency of both ups on same value and then your can synchronize the ups.
      Vinay kumar
  48. Arun
    Apr 25, 2017
    It’s awesome page..I love to visit the page but there are no answers posted for all the questions asked by the Engineers..And I would love to join this group on LinkedIn or FB to gain some knowledge about the EEE.Thank you so much guys for your time and patience.
    Anyone please suggest me a book or a site to learn from basics to the core subject of Electrical Engineering including the calculations.
    .You guys TC!!
  49. akshihs
    Apr 21, 2017
    Current capacity of aluminium cable
  50. Sreenath
    Feb 15, 2017
    Hi i have a question
    we require 100KVA DG as part of the factory setup can anyone explain how much capacity of transformer will be needed, is there a possibility to determine the transformer capacity based on the DG or let me know if you need the machinery list thanks in advance
    • vinay kumar
      Nov 15, 2017
      To calculate capacity of Transformer,you have to calculate the load of plant and also consider extension of load in future. then maximum load should be less than 80% of transformer capacity.It does not depend on your D.G availability.
      Vinay
    • Shahzad
      Mar 11, 2018
      In a 3 phase motor we use 10 mm cable one phase taking 40 amp for example how much total current of this motor
  51. Rohan Weerarathna
    Jan 23, 2017
    Can you give motors equations for Induction motors, DC Motors ect.
  52. Yogender
    Jan 05, 2017
    What is equivalent size of cable will be used for earthing of DG sets and Transformer instead of cu /GI strip
    Is considered the same cross sectional area or how to calculate
  53. Mubbashir
    Dec 27, 2016
    Esteemed sir
    I want to know how to calculate current carrying capacity per square mm Arial bunched cable.
  54. Franco George
    Dec 22, 2016
    Sir, please give details about how to bend an earth cable to be connected to diesel generator of 25 KVA. Give me an idea how to bend it.
  55. Muktinath Shil
    Dec 16, 2016
    Dear Sir,
    I want to know what is required AC cable size (in sqmm) for solar on grid 3phase 12.5kW inverter for inverter to ACDB?
    • atul
      May 11, 2018
      4cx16 sqmm Cu.
  56. Ravindra Raghuwanshi
    Dec 06, 2016
    We have infrared lamp resin curing plant & paper dryers. Total load is 330 KW. Connected with neutral and 3 phases i.e.each phase will have a load of 110 kw. Current 500 amp. What should the cable size and 3.5 core or 4 core. We will prefer copper.
  57. Rajendra Singh
    Oct 07, 2016
    how can we have check the copper nd aluminium cable size according to load via formula or trick ?
    this is very urgent for me, pls help me sir ASAP.
  58. M Ajay
    Sep 28, 2016
    Dear Sir,
    your above mentioned information is very useful.But please mention the load capacity of aluminium cables also..for 30sqmm copper cable we can put a load of 120A??
  59. Hasrat ali
    Aug 25, 2016
    Gd evening sir
    Pls told me sir
    How will be calculate cable size in mm^2
    Pls told me a short trik
    For example which size of cable should be use for 2500amp rating braker
    Pls sir as soon as possible rply me
  60. sujith thankachan
    Aug 23, 2016
    Thanks a lot sir
    this helping me more……..
  61. Priyanka Waikar
    Aug 15, 2016
    i just want solution for this. if i want to pass current of 1600 Ampere so what size of cable should i select?? cable size should in MM^2
    • Muhammad Ali Khan
      Aug 21, 2016
      It should be 400 Sq mm
  62. shivam
    Jun 27, 2016
    Sir, can you say that how a dc current of 2.5 amps will flow through a wire of resistance 60 ohms? input is 36 volts 11 ah battery
  63. Rholand Forescal
    Jun 20, 2016
    Sir please tell me why 1hp single phase motor is 7ampere in single phase motor chart in ampere. But if we use the formula in ohms law to get ampere in single phase I = hp / VxExPF we only get only 4.23 ampere when voltage is 230v power factor is 0.9 and i used 0.85 efficiency.. Please teached me how to prove the electrical thumb rules.
  64. Isuru
    May 31, 2016
    what is the difference between “Cu Wire Current Capacity” and Cable “Cable Current Capacity”?
    • pawan bhardwaj
      Aug 29, 2016
      For Cu Wire Current Capacity (Up to 30 Sq.mm) = 6X Size of Wire in Sq.mm
      Ex. For 2.5 Sq.mm = 6×2.5 = 15 Amp, For 1 Sq.mm = 6×1 = 6 Amp, For 1.5 Sq.mm = 6×1.5 = 9 Amp
      For Cable Current Capacity = 4X Size of Cable in Sq.mm, Ex. For 2.5 Sq.mm = 4×2.5 = 9 Amp.
  65. gurpreet
    May 28, 2016
    Plz tell me how to calculate size of generator set for a specific submersible pump set i.i for specific hp motor? Thanks alot
  66. Swapnendu Sil
    May 05, 2016
    pls tell me sir what cable needed for 32amp industrial socket and how we can determine if we need aluminium cable or cu cable or need 3 phase or single phase in general?
  67. Gopi nath
    Feb 24, 2016
    Super sir
  68. rudramurthy
    Dec 17, 2015
    7/16 cable size meanes what is the sqmm cable size in 3 phase supply 30kva load
  69. Balu B Nair
    Dec 07, 2015
    wonderful informative portal….!!!
  70. Pradeep Rathi
    Oct 15, 2015
    A perfect compilation. Thanks Jignesh. (Author)
  71. shah faisal
    Sep 29, 2015
    how i find cable for a suitable load like a if load is 23 which cable is-perfect for this load and how i find by formula ?
    • MD kashif
      Nov 17, 2015
      Plz tell me how to tabulate the armoured cable size for a particular load.
  72. gurjit
    Aug 11, 2015
    i am living in FLAT WITH 3 BED ROOMS ONE DRAWING ROOM AND HAVE 5 ACs 2 TR AND WASHING MACHINE INDUCTION COOKER AND MICROWAVE WITH GEYSERS 25 LITERS IN BED ROOMS AND KITCHEN AND THE LOAD GRANTED IS 8KW.
    THE EARTHING WIRE FROM MCB BOARD ON FIRST FLOOR TO METER ON GF IS OF 1 MM SQUARE .
    IS THIS ENOUGH OR SHOULD I REPLACE WITH HIGHER CAPACITY
    • Rehan
      Oct 08, 2015
      No Its not enough
      If you are having a single phase meter use 1 no of 4 sq mm Cu wire
      and if you are having a 3 phase meter use 2 nos of 4 sq mm wires
  73. ankesh mishra
    Aug 02, 2015
    Tell me the short cut for calculating load for a flat
  74. Deepak Kumar
    Jul 06, 2015
    Please tell me how to find current rating of the conductor
  75. mohan dass
    Jul 03, 2015
    Can we use 2 run of 25 mm sq instead of 50 mm sq cable of Cu. If yes then tell me full details and If not then tell me also full details.
  76. manish chovatia
    May 21, 2015
    How many distance between transformer and diesel genrator as per ie rules
  77. sowmya
    May 01, 2015
    I have a current transformer with 1 main meter outside the building and a control panel having 5 CT meters with black round coils inside the building. I want to know, A) when current pass through the Transformers, will the current be reduced or be the same and after that B) when current pass through the CT meters with black round coils, will the current be reduced or be the same. C) in the above process will the reading of the main meter be same or different, from the total reading of all the 5 CT meters.
  78. swapneswar pradhan
    Apr 07, 2015
    What is the simple formula for electrical, current , voltage
  79. swapneswar pradhan
    Apr 07, 2015
    Thanks sir u help for electrical problem .
  80. omar
    Feb 08, 2015
    we known low pf increase line current so does it increase kwh reading in metering…but pf varation is related also actually totally in reactive part…so what is the impact of pf in metering.
  81. Bassey Friday
    Jan 31, 2015
    Please .I have a 500KVA what % of load should I load it considering the fact that max load is about 700Amp
    • Etop Inyang
      Aug 22, 2015
      Is your generator sets for emergency supply or prime supply? For Prime you can load up to 100% and 70% for emergency generator sets.
  82. mdmukhter
    Jan 03, 2015
    I want to take part in to the technical debates and weekly technical discussion.
  83. abdelsalam mikky
    Dec 22, 2014
    How diesel engine frame should be grounded (I think shall be two earthing diagonal points ) according to NFPA 70 (NEC), could you please provide the supporting standard cod of this
      Every Genset has predefined points to ground engine frame. Don’t forget to ground gas reservoir if it exist.
  84. madhu
    Nov 18, 2014
    How to calculate Cable sizes for the Below in thumb rule,
    01.Single core cable above 30Sqmm
    02.Three phase cable size.
    Pls send it with a clear Example
  85. rahul
    Oct 15, 2014
    what is maximum distance between VCB panel and transformer at 11 kv voltage supply using HT cable of size 3cX95sqmm. Is it ok that transformer is installed at 150 meter away from VCB panel.
    • ali
      Nov 08, 2014
      minimum 6 mtrs
  86. JOYDEEP KUNDU
    Oct 06, 2014
    SIR I JUST WANT TO KNOW THAT IN 3PHASE 4 WIRE ELECTRICAL DISTRIBUTION SYSTEM WHY THE RADIUS OF NEUTRAL WIRE IS LESS THAN OTHER WIRE?
    • kalpesh
      Aug 06, 2015
      Because in 3 phase 4 wire system only unbalance current pass from the nutural so current is never higher then half of the phase current,so purpose of aluminium saving its samller size then phase in power cable of higher size
  87. balu
    Oct 01, 2014
    Dear sir,
    Please send me your mobile number because I talk personally with you so I request you please give me your mobile number
    Thanks&Regards
    Vagh Balu R
    7698260140
    • Huj
      Oct 03, 2014
      Dear Jebalu, are ju crazy. There is inernet, no personalities!
  88. Arnel
    Sep 22, 2014
    what is the meaning of 2×6+4 for wire sizing?
  89. R Knight
    Sep 21, 2014
    What do you reckon on SWA 3 phase and Neutral Cable size?
    Circuit 1
    primary fuses, 16A and 20A = 36A
    However, connected load is 9kVA and 3kVA = 17.3A and average consumption is 3kVA and 2kVA respectively, giving ~ 8A
    Circuit 2
    Primary fuses, 40A, 16A, 16A and 16A = 88A
    However, nominal current is 33A, 6A, 8A and 11A, giving ~ 58A
    Circuit 2
    11kw fan with a 32amp supply
    on Cable run of 150m
  90. kushvendra tyagi
    Sep 17, 2014
    If the load requirement is 1200 kva , what kind of independent feeder should be considered , 11th or 33 kv
  91. Glenn
    Sep 03, 2014
    Hi need clarification to choose between 3 core, 3.5 core and 4 core for cable selection application. I know we choose 3.5 core and above in case of unbalanced loads any advice on making selection more clear is greatly appreciated
  92. Thuong.nguyen
    Jul 12, 2014
    1 Phase Motor draws Current = 7Amp per HP.
    Full Load Current of 1 Phase Motor = HPx6
    I think full load current of 1 phase is too high, for examples, in catalog of manufacture, current of 1 phase motor 4HP only about 12A. Moreover, please clarify why percent of draw current and full load current is small (7/6), as i know that factor is 3/1.( In my country, there used 220V for line voltage and 380V for phase voltage). The same question for 3 phase motor.
  93. Muhammad Bilal
    Apr 15, 2014
    What is the difference between line and phase?
    • Ganesh Kaneriya
      Jul 18, 2014
      line to line voltage means voltage between 2 line
      and Phase voltage means voltage between 1 line and neutral
  94. neeraj kumar
    Apr 06, 2014
    thanks 4 d info it was really
    help full we all must share
    these things so we could get best of
    knowledge
  95. Joe C.
    Dec 25, 2013
    Please I have some business proposals for the author.
    Please get in touch with me at [email protected]
  96. Annu
    Oct 28, 2013
    Thanks Dear sharing Such valuable data
  97. nmr
    Oct 03, 2013
    sirs, for aluminium cables and wires current carrying was not indicated in the thumb rules.
  98. aakifnouman
    Sep 02, 2013
    Thank You For This and for those u cant understand this is only a thumb rule just to understand and remember
  99. sumitfloyd
    Sep 02, 2013
    On the section current capacity of Equipments, it is written
    # 1 Phase Motor draws Current = 7Amp per HP.
    # 3 Phase Motor draws Current = 1.25Amp per HP.
    I am not quite clear on these points. Please clarify. Does it mean if we have 3HP single phase motor then it will draw 21Amp current throughout its operation or during its starting?
  100. kriloter
    Aug 28, 2013
    These rules could be a little bit tricky unless you don’t know further connections …
    Not all of them are aplicable in a different distribution systems worldwide, especially constants like •Current Rating of Transformer = KVA x 1.4, etc.
    I suggest author should notice the conditions and input values in which are these rules aplicable and users should modify them according to a specific distribution system.
    • alam
      Mar 14, 2014
      well said mate.!
  101. shaijal100
    Aug 24, 2013
    pls tell me the difference between wire and cable.You mentioned different capacity for cu wire and a cable. You mean cable with aluminium conductor or something else..?Pls tell me..
    • kriloter
      Aug 28, 2013
      cable is bunch of wires :-)
  102. manjunatha_pm
    Aug 24, 2013
    Please give me the solution for below mentioned problem..
    Actually in our plant we having two 500 kva DG set and One dg is new one and other one is old …efficiency is different, so when switch on both and synchronizing.. some problem is occurring and i am not able to synchronizing. .. please give any solution for this problem
    my mail id is [email protected]
    • srinivas subramani
      Nov 19, 2013
      Dear friend, just find the settings configuration in PCC2100 relay for parameter settings:)
  103. ChAliGhafoor
    Aug 23, 2013
    kindly inform frm where did u get this useful information?
