Continued from: Electrical Thumb Rules You MUST Follow (Part 6)
8 electrical thumb rules to follow:
- Overhead conductor / cable size
- Transmission / distribution line (span, height of tower)
- Types of towers
- Tower swing angle clearance (metal part to live part)
- Cable coding, IS 1554 (A2XFY, FRLS, FRPVC, FRLA, PILC)
- Corona ring size
- Load as per Sq.Ft
- Size of ventilation shaft
1. Overhead conductor / cable size
Voltage | Overhead Conductor | Cable Size |
33 KV | ACSR-Panther/Wolf/Dog , AAAC | 150,185,300,400,240 mm2 Cable |
11 KV | ACSR-Dog/Recon/Rabbit , AAAC | 120, 150,185,300 mm2 Cable |
LT | ACSR-Dog/Recon/Rabbit , AAC, AAAC | 95,120, 150,185,300 mm2 Cable |
2. Transmission / distribution line (span, tower height)
Span | Height of Tower |
400KV = 400 Meter | 400KV=30Meter (Base 8.8 Meter) |
220KV = 350 Meter | 220KV=23Meter (Base 5.2 Meter) |
132KV = 335 Meter | 220KV Double Circuit=28 Meter |
66KV = 210 Meter | 66KV=13Meter |
Conductor Ampere | Voltage wise Conductor |
Dog = 300Amp | 400KV=Moose ACSR=500MVA Load |
Panther = 514Amp | 220KV=Zebra ACSR=200MVA Load |
Zebra = 720Amp | 132KV=Panther ACSR=75MVA Load |
Rabbit = 208Amp | 66KV=Dog ACSR=50MVA Load |
Moose = 218Amp |
3. Types of Towers
Type | Used | Angle/Deviation |
A | Suspension Tower | Up to 2° |
B | Small Angle Tower | 2° to 15° |
C | Medium Angle Tower | 15° to 30° |
D | Large Angle / Dead End Tower | 30° to 60° & Dead End |
4. Tower Swing Angle Clearance (Metal Part to Live Part)
Swing Angle | Live Part to Metal Part Clearance (mm) | |||
66KV | 132KV | 220KV | 400KV | |
0° | 915mm | 1530mm | 2130mm | 3050mm |
15° | 915mm | 1530mm | 2130mm | – |
22° | – | – | – | 3050mm |
30° | 760mm | 1370mm | 1830mm | – |
44° | – | – | – | 1860mm |
44° | 610mm | 1220mm | 1675mm | – |
5. Cable Coding, IS 1554 (A2XFY/FRLS/FRPVC/FRLA/PILC)
A | Aluminium |
2X | XLPE |
F | Flat Armoured |
W | Wire Armoured |
Y | Outer PVC Insulation Sheath |
W | Steel Round Wire |
WW | Steel double round wire Armoured |
YY | Steel double Strip Armoured |
FR | Fire Retardation |
LS | Low Smoke |
LA | Low Acid Gas Emission |
WA | Non Magnetic round wire Armoured |
FA | Non Magnetic Flat wire Armoured |
FF | Double Steel Round Wire Armoured |
6. Corona Ring Size
Voltage | Size |
<170 KV | 160mm Ring put at HV end |
>170 KV | 350mm Ring put at HV end |
>275 KV | 450mm Ring put at HV end & 350 mm Ring put at Earth end |
7. Load as per Sq.Ft
Type of Load | Load/Sq.Ft | Diversity Factor |
Industrial | 1000 Watt/Sq.Ft | 0.5 |
Commercial | 30 Watt/Sq.Ft | 0.8 |
Domestic | 15 Watt/Sq.Ft | 0.4 |
Lighting | 15 Watt/Sq.Ft | 0.8 |
8. Size of Ventilation Shaft
Height of Building in meter | Size of ventilation shaft in sq meter | Minimum size of shaft in meter |
9.0 | 1.5 | 1.0 |
12.5 | 3.0 | 1.2 |
15 and above | 4.0 | 1.5 |
Dear sir,
I want know how to select MCCB breaker with kA rating of the Load.
L.Prakash
Dear Sir,
We have in our transmission 400kV system high Corona losses
I will appreciate if could provide me with any related information.
Sir i want knowcontrolling wiring iec codes for vaccum circuit breakers i.e ferrules code j means d.c voltage,k means controll signals and more can i get it
I want more information about LT-HT installation, testing, commissioning. And also a energy audit , green energy.
