Home / Technical Articles / High Voltage / FACTS Devices To Enhance Power System Performance
The FACTS //
Flexible Alternating Current Transmission System
Flexible Alternating Current Transmission System (FACTS) simply refers to a combination of power electronics components with traditional power system components. They are intended to improve our power system reliability, power transfer capability, transient and dynamic stability improvements, voltage regulation etc…
FACTS Devices To Enhance Power System Performance (An ABB SVC Light® rated at 13.2 kV, 0-64 Mvar (capacitive) has been installed at the Gerdau plant in Charlotte, N.C., USA operating an electric arc furnace (EAF) with continuous charging for scrap-based steel production; credit: ABB)
With the advent of improved semiconductor technologies, these FACTS devices have been proven in their speed and flexibility. But there do exist some cost and complexity issues.
There can be series as well as shunt compensation for the transmission lines using these FACTS devices. In series compensation, line impedance is modified, that means net impedance is decreased and thereby increasing the transmittable active power. For shunt compensation, reactive current is injected into the line so as to regulate the voltage at the point of connection.
Thus, the active power transmission is increased. In both types of compensations (series and shunt), more reactive power must be provided.
The general classification of these FACTS devices is as //
  1. Series controllers
  2. Shunt controllers
  3. Combined series-series controllers
  4. Combined series-shunt controllers
Series Controllers
Series controllers are being connected in series with the line as they are meant for injecting voltage in series with the line. These devices could be variable impedances like capacitor, reactor or power electronics based variable source of main frequency, sub synchronous or harmonic frequency, or can be a combination of these, to meet the requirements.
If the injected voltage is in phase quadrature with the line current, then only supply or consumption of variable reactive power is possible.
Series FACTS Controllers
Series FACTS Controllers (figure credit: intechopen.com)
In order to handle real power also, any other phase relationship has to be involved. These type of controllers include:
  • SSSC – Static synchronous series compensator,
  • TCSC – Thyristor controlled series capacitor,
  • TCSR – Thyristor controlled series reactor,
  • TSSC – Thyristor switched series capacitor and
  • TSSR – Thyristor switched series reactor.
Go back to FACTS devices ↑
Shunt controllers
Shunt controllers will be connected in shunt with the line so as to inject current into the system at the point of connection. They can also be variable impedance, variable source, or a combination of these.
If the injected line current is in quadrature with the line voltage, variable reactive power supply or consumption could be achieved. But any other phase relationship could involve real power handling as well.
Shunt FACTS Controller
Shunt FACTS Controller (figure credit: intechopen.com)
This category includes STATCOM (Static synchronous compensator) and SVC (Static VAR compensator). The common Static VAR compensators are:
  • TCR – Thyristor controlled reactor,
  • TSR – Thyristor switched reactor,
  • TSC – Thyristor switched capacitor,
  • etc…
Combined Series-Series Controllers
This category comprises of separate series controllers controlled in a coordinated manner in the case of a multiline transmission system. It can also be a unified controller in which the series controllers perform the reactive power compensation in each line independently whereas they facilitates real power exchange between the lines via the common DC link.
Because, in unified series-series controllers like Interline Power Flow Controller (IPFC), the DC terminals of the controller converters are all connected together.
Combined Series-Shunt Controllers
It is a combination of separate series and shunt controllers, being operated in a coordinated manner. Hence, they are capable of injecting current into the line using the shunt part and injecting series voltage with the series part of the respective controller.
If they are unified, there can be real power exchange between the shunt and series controllers via the common DC power link, as in the case of Unified Power Flow Controllers (UPFC).
Unified Power Flow Controllers – UPFC (figure credit: intechopen.com)
The important advantages of these FACTS controllers includes //
  1. Improving power transfer capability
  2. Confining power flow to designated routes
  3. Transient and dynamic stability improvement
  4. Damping of power system oscillations
  5. Better voltage regulation
  6. Flexible operation and control of the system
  7. Secure loading of the transmission lines close to their thermal limits
  8. Prevention of cascading outages by contributing to emergency control
Minimizing the cost //
In short, FACTS technology enables the enhancement of power system performance. Researches are going on with the intension of minimizing the cost of the power electronics components.
But with respect to the losses incurred in a power system, incorporation of these FACTS devices to mitigate them could be considered as cost effective.
An example of installed SVC //
An ABB SVC Light rated at 13.2 kV, 0-64 Mvar (capacitive) has been installed at the Gerdau plant in Charlotte, N.C., USA operating an electric arc furnace (EAF) with continuous charging for scrap-based steel production. The EAF, rated at 30/33 MVA, as well as a ladle furnace (LF) rated at 18 MVA are taking their power from a 100 kV supply grid.
The fast control of SVC Light will improve the power quality and particularly reduce the flicker levels generated.
FACTS SVC single line diagram
The electric arc furnace (EAF) is fed from a double 100 kV sub-transmission circuit. Various scenarios for improved flicker mitigation were considered, such as re-conductoring the existing 100 kV lines, building a dedicated 3rd 100 kV line to the plant, or replacing the existing SVC with a STATCOM, a faster, more powerful flicker mitigating device than a conventional SVC (credit: ABB)
An introduction to SVC – Static Var Compensator
Static Var Compensators (SVCs) in Dallas
SVC PLUS – Static Var Compensator PLUS
Sajna Soman
Graduate in Electrical and Electronics Engineering from Kerala University, India. Currently, pursuing Master's degree in Power Electronics & Power Systems. Interested in Power System Engineering as well as Illumination Technologies. Present on Google+ and LinkedIn.
6 Comments
  1. Mark McCloy
    Jul 31, 2017
    Well done. Is Circuit synchronization and damping inherently (physics) achieved or are there specific control aspects/commands programmed via the IED’s and/or switching capacitors, thyristors?
    Also, how important is Ground to these systems?
  2. Ajay John
    Oct 23, 2015
    Good
  3. Asemokhe Genesis
    Oct 15, 2015
    Excellent work.
  4. Very good article
    Oct 08, 2015
    I have taken this topic for my Btech (jntuh) final year project, really its good article
  5. naser
    Oct 02, 2015
    HI
    i am interested to receive disquisition/article about “Network-Protection-And-Automation”.
    is possible to help me?
    best regards,
    N.Ehya
  6. Midhun krishnan
    Sep 28, 2015
    Good article indeed .Gud work….
