Home / Technical Articles / Why does generator-current breaking differ from other switching devices in T&D systems
Generator-current breaking
There are few switching situations that differ from the duties standardized for switching devices in transmission and distribution systems. One of these special situations are generator-current breaking. Generator circuit-breakers are breakers applied at a rated voltage matching the rated voltage of a generator.
Why does generator-current breaking differ from other switching devices in T&D systems (on photo: Generator Circuit-Breaker Systems type HECPS by ABB)
They are located between the generator and step-up transformer. When no generator circuit-breaker is applied, an alternative solution is a circuit-breaker at the high voltage side of the step-up transformer.
The advantage of this solution is the less complicated simple high-current connection (generator bus duct) between generator and transformer.
The advantage of having a generator circuit-breaker is the possibility to connect the auxiliary plant to the medium voltage side of the (permanently energized) step-up transformer. This is depicted later below in Figure 3.
The electrical and mechanical performances of a generator circuit-breaker are very different from standard MV distribution switchgear. The only standard available worldwide that covers specifically the requirements for generator circuit-breakers is ANSI/IEEE C37.013.
Premium Membership Required
Limited time offer! – Save 15% on Pro Membership Plan with discount code LRN15
Log In »Purchase »
40  ⁄    =  five
