Home / Technical Articles / How to Select Right Frequency Converter for Variable Speed Drive (VSD)?
Application: Brackish water - 3 APP 2,2 equiped with Danfoss inverters for flexible use at universety. Place of installation: UK
Application: Brackish water – 3 APP 2,2 equiped with Danfoss inverters for flexible use at universety. Place of installation: UK
Selecting of a frequency converter for variable speed drives requires a lot of experience. If the experience is not available, it is often useful to visit either a reference plant with similar applications, or exhibitions or trade shows.
Checklist
The following is a brief checklist of points that should be considered:
  1. Details of the machine to be controlled
  2. Environmental details
  3. Mains
  4. Maintenance, operation, personnel
  5. Financial criteria
  6. Protective measures for operators/converter/motor
  7. Standards/regulations
  8. Environmental considerations
  9. Also important…
VLT Drives Applications (VIDEOS)
Some of the interesting applications done with Danfoss VLT drives:
  1. VLT drives in large desalination plant
  2. VLT drives control cooling tower fans
  3. VLT control optimizes spindle speed in Indian textile factory
  4. VLT frequency converters drive bagage handling system
  5. VLT Drives Save 78% Energy in Chester Zoo
  1. Required plant/machine characteristics
  2. Torque characteristics, stalling torque, acceleration torque
  3. Speed control range, cooling
  4. Power consumption of the converter and the motor
  5. Operating quadrants
  6. Slip compensation (dynamic)
  7. Required ramp-up and ramp-down times
  8. Required braking times, brake operating time
  9. Direct drives, gears, transmission components, moment of mass inertia
  10. Synchronisation with other drives
  11. Operating time, controls
  12. Computer linkage, interfaces, visualisation
  13. Design and protection type
  14. Possibility of integrating decentral intelligence in the frequency converter
Go up to the Checklist ↑
  1. Installation height, ambient temperature
  2. Cooling requirements, cooling options
  3. Climatic conditions, such as humidity, water, dirt, dustgas-es
  4. Special regulations, e.g. for mining, the chemical industrythe ship building industry, food technology
  5. Acoustic noise
3. Mains
  1. Mains voltage, voltage fluctuations
  2. Mains performance
  3. Mains frequency fluctuations
  4. Mains interference
  5. Short-circuit and overvoltage protection
  6. Mains drop-out
  1. Training and instruction of operators
  2. Maintenance
  3. Spare parts/spare units
  1. Purchase costs (components)
  2. Space requirement, integrated installation, design
  3. Installation costs
  4. Commissioning of the system
  5. Set-up costs
  6. Operating costs
  7. Efficiency of the system (frequency converter and machine)
  8. Reactive power requirement and compensation for harmonic loads
  9. Product lifetime
  1. Galvanic isolation in accordance with PELV
  2. Phase drop-out
  3. Switching at the converter output
  4. Earth and short-circuit protection
  5. Motor coils to reduce voltage rise times
  6. Electronic thermal monitoring and connection of thermistors
  1. National DIN, BS, UL, CSA, VDE, European EN
  2.  International IEC, CE, etc.
  1. Ability to recycle the product
  2. Manufacturing practice
  3. Energy saving factors
Also important…
Using this checklist a frequency converter can be selected which covers most of the items as standard, but you should also double check whether:
  • The converter has mains or intermediate circuit chokes in order to greatly reduce mains interference
  • A RFI filter for class A or B is standard or has to be purchased separately
  • Motor derating is required if a frequency converter is used
  • The converter itself is protected against earth and short-circuit
  • The converter reacts adequately in a fault situation.
Go up to the Applications ↑
4. LT frequency converters drive bagage handling system
5. LT Drives Save 78% Energy in Chester Zoo
Resource: Fact Worth Knowing About Frequency Converters – Danfoss
6 Comments
  1. Derin
    Jun 24, 2015
    Hello,
    Nice work here. Is there any partparticular expreexpression for sizing speed drive?
  2. Dorin Pestereanu
    Jun 17, 2014
    Very , very useful ; I’ve worked with variable speed drives, so I know the subject ; Many thanks for your effort !
  3. tarekdia
    Dec 23, 2012
    why not make a downloadable version of the article in the form of pdf file so it can be read later
    thanks for the effort
      Hi Tarekdia,
      You can make PDF of any technical article using link ‘Get PDF’ at the top of article, below title on the right.
      You can optimize your PDF, set font size and remove images as well.
  +  36  =  forty three
