Home / Technical Articles / MCset – Air Insulated Switchgear with SF6 CB
MCset Air Insulated Switchgear with SF6 CB (up to 24kV)
General about MCset
MCset is Schneider Electric‘s AIS – Air Insulated Switchgear (indoor metal-enclosed device) intended for the MV section of HV/MV substations and high power MV/MV substations up to 24kV.
Main component of MCset is circuit breaker which is SF6 type.
MCset – Air Insulated Switchgear offers:
  • Pre-engineered and adaptable solutions tailored to your customer’s requirements
  • Significantly reduced maintenance
  • Local support centres throughout the world.
Technical characteristics
The values below are given for the normal operating conditions as defined in IEC 62271-200 and 62271-1.
MCset technical characteristics
IAC (internal arc classification)
The metal enclosed switchgear may have different types of accessibility on the various sides of its enclosure. For identification purposes concerning the different sides of the enclosure, the following code shall be used (according to the IEC 62271-200 standard):
A – restricted access to authorised personnel only
F – access to the front side
L – access to the lateral side
R – access to the rear side.
MCset switchboard structure
Functional unit
A functional unit consists of all of the equipment in the main and auxiliary circuits which together provide a protection function.
Each functional unit combines all of the components which are required to fulfil function: the cubicle, and the protection, monitoring and control system (including the withdrawable live part).
Accessibility of the MV compartments
There are two types of compartments:
Interlock-controlled accessible compartment which contains withdrawable MV part (circuit breaker, contactor) compartment for AD/RHC/RHB/CL units, and
Tool-based accessible compartments which contains cable compartment, main busbar for the AD/RHC/ CL/GL/DI units, busbar compartment for the RHB, bottom busbar compartment for the CL/GL units and fixed bridge compartment for the GL unit.
Structure of an MCset switchboard
MCset switchboards are made up of several interconnected functional units. The power connections are made between the functional units within a switchboard via a single busbar.
The electrical continuity of all of the metal frames is provided by the connection of each functional unit’s earthing busbar to the switchboard’s main earthing circuit. Low voltage wiring trays are provided in the switchboard above the low voltage control cabinets.
Low voltage cables can enter the switchboard through the top or bottom of each functional unit.
MCset apparatus
MCset apparatus
Functions
The cubicle is of LSC2B (Loss of Service Continuity Category) type as defined by IEC standard 62271-200, in other words the medium voltage parts are compartmented using metal partitions (PM class) which are connected to earth and which separate:
  1. The busbars
  2. The withdrawable part (circuit breaker, fuse-contactor, disconnector truck or earthing truck)
  3. MV connections, earthing switch, current sensors and voltage transformers as required.
MCset guarantees a high level of protection of people; when a compartment containing a main circuit is open, the other compartments and/or functional units may remain energised.
The low voltage auxiliaries and monitoring unit are in a control cabinet separated from the medium voltage section.
Cubicle types
Four basic cubicle layouts are offered:
  1. Incomer or feeder AD
  2. Line up bussection CL – GL
  3. Busbar metering and earthing TT
  4. Switch-fuse feeder DI
AD and CL cubicles have withdrawable switchgear.
Incomer or feeder – AD type cubicles
Incomer or feeder - AD 1-2-3 type cubicles
Incomer or feeder – AD 1-2-3 type cubicles
MV/LV devices
  1. Busbars for cubicle interconnection
  2. Main switching device
  3. MV connections by cables accessible from the front face
  4. Earthing switch
  5. Current sensors
  6. Voltage Transformers (optionally equipped with withdrawable fuses)
  7. LV control cabinet – Low voltage auxiliaries and the protection, monitoring and control unit are in a control cabinet which is separated from the medium voltage part
CL – GL type cubicles – Line-up bussectioning
CL - GL type cubicles - Line-up bussectioning
MV/LV devices
  1. Busbars to connect the bussectioning functional unit with other switchboard functional units
  3. Current sensors
  4. Voltage Transformers (optionally equipped with withdrawable fuses)
  5. LV control cabinet – Low voltage auxiliaries and protection, monitoring and control unit are in one control cabinet, separated from the medium voltage part
TT type cubicles – Metering – Busbar earthing
TT type cubicles - Metering - Busbar earthing
MV/LV devices
  1. Busbars to connect the TT functional unit with other switchboard cubicles
  2. Earthing switch
  3. Voltage Transformers (optionally equipped with withdrawable fuses)
  4. LV control cabinet – Low voltage auxiliaries and the protection, monitoring and control unit are in a control cabinet which is separated from the medium voltage part
DI type cubicles – Fuse-switch feeder
DI type cubicles - Fuse-switch feeder
MV/LV devices
  1. Busbars to connect the DI functional unit with other switchboard cubicles
  2. Switch – earthing switch
  3. MV fuses
  4. LV control cabinet – Low voltage auxiliaries and protection, monitoring and control unit are in one control cabinet, separated from the medium voltage part
MCset medium voltage switchgear up to 24kV (VIDEO)
Seismic type test performed on MCset (VIDEO)
Reference: MCset and PIX AIS switchgears catalogu 2010 – Schneider Electric
  1. Agnetta Nandi
    Sep 09, 2023
    what is the cost of 1. Mcset air insulated switchgear upto 24kv. 2. MNS-SG Low voltage, Metal-Enclosed, Switch Gear and shipment charges to Liberia.
  2. LI Xinglong
    Apr 18, 2015
    Is it a new switchgear?
Leave a Reply to LI Xinglong
three  ×  three  =
