Home / Technical Articles / Reactive power and power factor measurement in industrial plant
Reactive power measurement
A varmeter is used to measure the reactive power in an industrial plant that is supplied by an 8300-V, three-phase, four-wire line. The plant load is estimated to be 300 kVA at 0.8 pf.
Reactive power & power factor measurement in industrial plant
Reactive power and power factor measurements in a plant
Design a suitable measuring system.
Figure 1 - Three-phase, four-wire wattmeter circuit.
Figure 1 – Three-phase, four-wire wattmeter circuit.
Calculation Procedure
1. Select Varmeter
The high-line voltage and large load dictate the use of a three-phase varmeter (rated at 120V, 5A) with current and potential transformers.
Premium Membership Required
Limited time offer! – Save 15% on Pro Membership Plan with discount code LRN15
Log In »Purchase »
twenty six  −    =  seventeen
