Complex Power
Formulas
When a voltage V causes a current I to flow through a reactive load Z, the complex power S is:
S = VI* where I* is the conjugate of the complex current I.
Inductive Load
Z = R + jXL
I = IP – jIQ
cosf = R / |Z| (lagging)
I* = IP + jIQ
S = P + jQ
An inductive load is a sink of lagging VArs (a source of leading VArs).
Capacitive Load
Z = R – jXC
I = IP + jIQ
cosf = R / |Z| (leading)
I* = IP – jIQ
S = P – jQ
A capacitive load is a source of lagging VArs (a sink of leading VArs).
NOTATION
The symbol font is used for some notation and formulae. If the Greek symbols for alpha beta delta do not appear here [ a b d ] the symbol font needs to be installed for correct display of notation and formulae.
B
C
E
f
G
h
I
j
L
P
Q
susceptance
capacitance
voltage source
frequency
conductance
h-operator
current
j-operator
inductance
active power
reactive power
[siemens, S]
[farads, F]
[volts, V]
[hertz, Hz]
[siemens, S]
[1Ð120°]
[amps, A]
[1Ð90°]
[henrys, H]
[watts, W]
[VAreactive, VArs]
Q
R
S
t
V
W
X
Y
Z
f
w
quality factor
resistance
apparent power
time
voltage drop
energy
reactance
admittance
impedance
phase angle
angular frequency
[number]
[ohms, W]
[volt-amps, VA]
[seconds, s]
[volts, V]
[joules, J]
[ohms, W]
[siemens, S]
[ohms, W]
[degrees, °]
[rad/sec]
Don't miss anything!
Powered by MailChimp
  1. vijay chakrawar
    Feb 16, 2012
    Resp. Sir,
    I want details of solar pump, BLDC, PMMP also need installation methods.
    If possible please give names of Indian sources.
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Want to live and use energy on Mars? Why not?
The problem of energy accessibility and production on Mars is one of the three main challenges for the upcoming colonisation...
Sudden pressure relay in oil-filled power transformer
Internal arcing in an oil-filled power transformer can instantly vaporize surrounding oil, generating gas pressures that can cause catastrophic failure,...
Gas-Insulated Substations – GIS
Superior Dielectric Gas A gas-insulated substation (GIS) uses a superior dielectric gas, SF6, at moderate pressure for phase-tophase and phase-to-ground...
Close
