Symmetrical Components
Formulas
In any three phase system, the line currents Ia, Ib and Ic may be expressed as the phasor sum of:
- a set of balanced positive phase sequence currents Ia1, Ib1 and Ic1 (phase sequence a-b-c),
- a set of balanced negative phase sequence currents Ia2, Ib2 and Ic2 (phase sequence a-c-b),
- a set of identical zero phase sequence currents Ia0, Ib0 and Ic0 (cophasal, no phase sequence).
The positive, negative and zero sequence currents are calculated from the line currents using:
Ia1 = (Ia + hIb + h2Ic) / 3
Ia2 = (Ia + h2Ib + hIc) / 3
Ia0 = (Ia + Ib + Ic) / 3
The positive, negative and zero sequence currents are combined to give the line currents using:
Ia = Ia1 + Ia2 + Ia0
Ib = Ib1 + Ib2 + Ib0 = h2Ia1 + hIa2 + Ia0
Ic = Ic1 + Ic2 + Ic0 = hIa1 + h2Ia2 + Ia0
The residual current Ir is equal to the total zero sequence current:
Ir = Ia0 + Ib0 + Ic0 = 3Ia0 = Ia + Ib + Ic = Ie
which is measured using three current transformers with parallel connected secondaries.
Ie is the earth fault current of the system.
Similarly, for phase-to-earth voltages Vae, Vbe and Vce, the residual voltage Vr is equal to the total zero sequence voltage:
Vr = Va0 + Vb0 + Vc0 = 3Va0 = Vae + Vbe + Vce = 3Vne
which is measured using an earthed-star / open-delta connected voltage transformer.
Vne is the neutral displacement voltage of the system.
The h-operator
The h-operator (1Ð120°) is the complex cube root of unity:
h = – 1 / 2 + jÖ3 / 2 = 1Ð120° = 1Ð-240°
h2 = – 1 / 2 – jÖ3 / 2 = 1Ð240° = 1Ð-120°
Some useful properties of h are:
1 + h + h2 = 0
h + h2 = – 1 = 1Ð180°
h – h2 = jÖ3 = Ö3Ð90°
h2 – h = – jÖ3 = Ö3Ð-90°
NOTATION
The symbol font is used for some notation and formulae. If the Greek symbols for alpha beta delta do not appear here [ a b d ] the symbol font needs to be installed for correct display of notation and formulae.
B
C
E
f
G
h
I
j
L
P
Q
susceptance
capacitance
voltage source
frequency
conductance
h-operator
current
j-operator
inductance
active power
reactive power
[siemens, S]
[farads, F]
[volts, V]
[hertz, Hz]
[siemens, S]
[1Ð120°]
[amps, A]
[1Ð90°]
[henrys, H]
[watts, W]
[VAreactive, VArs]
Q
R
S
t
V
W
X
Y
Z
f
w
quality factor
resistance
apparent power
time
voltage drop
energy
reactance
admittance
impedance
phase angle
angular frequency
[number]
[ohms, W]
[volt-amps, VA]
[seconds, s]
[volts, V]
[joules, J]
[ohms, W]
[siemens, S]
[ohms, W]
[degrees, °]
[rad/sec]
Don't miss anything!
Powered by MailChimp
  1. [...] : http://electrical-engineering-portal.com/resources/knowledge/electrical-formulas/symmetrical-compone... ShareLike this:LikeBe the first to like this post. Categories: Uncategorized | Leave a [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Transformer Losses Standards
Unlike many countries around the world, Europe has no mandatory standard on energy efficiency of distribution transformers. The two main...
Principles for Controlling Harmonics
Harmonic distortion is caused by nonlinear devices in the power system. A nonlinear device is one in which the current...
Internal arc testing of MV switchgear – IEC 62271-200 (part two)
Continued from: Internal arc testing of MV switchgear – IEC 62271-200 (part one) Expiriences with IEC 62271-200 in case of...
Close
