Three Phase Fault Level
Formulas
The symmetrical three phase short-circuit current Isc of a power system with no-load line and phase voltages Eline and Ephase and source impedance ZS per-phase star is:
Isc = Ephase / ZS = Eline / Ö3ZS
The three phase fault level Ssc of the power system is:
Ssc = 3Isc2ZS = 3EphaseIsc = 3Ephase2 / ZS = Eline2 / ZS
Note that if the X / R ratio of the source impedance ZS (comprising resistance RS and reactance XS) is sufficiently large, then ZS » XS.
Transformers
If a transformer of rating ST (taken as base) and per-unit impedance ZTpu is fed from a source with unlimited fault level (infinite busbars), then the per-unit secondary short-circuit current I2pu and fault level S2pu are:
I2pu = E2pu / ZTpu = 1.0 / ZTpu
S2pu = I2pu = 1.0 / ZTpu
If the source fault level is limited to SS by per-unit source impedance ZSpu (to the same base as ZTpu), then the secondary short-circuit current I2pu and fault level S2pu are reduced to:
I2pu = E2pu / (ZTpu + ZSpu) = 1.0 / (ZTpu + ZSpu)
S2pu = I2pu = 1.0 / (ZTpu + ZSpu)
where ZSpu = ST / SS
NOTATION
The symbol font is used for some notation and formulae. If the Greek symbols for alpha beta delta do not appear here [ a b d ] the symbol font needs to be installed for correct display of notation and formulae.
B
C
E
f
G
h
I
j
L
P
Q
susceptance
capacitance
voltage source
frequency
conductance
h-operator
current
j-operator
inductance
active power
reactive power
[siemens, S]
[farads, F]
[volts, V]
[hertz, Hz]
[siemens, S]
[1Ð120°]
[amps, A]
[1Ð90°]
[henrys, H]
[watts, W]
[VAreactive, VArs]
Q
R
S
t
V
W
X
Y
Z
f
w
quality factor
resistance
apparent power
time
voltage drop
energy
reactance
admittance
impedance
phase angle
angular frequency
[number]
[ohms, W]
[volt-amps, VA]
[seconds, s]
[volts, V]
[joules, J]
[ohms, W]
[siemens, S]
[ohms, W]
[degrees, °]
[rad/sec]
Don't miss anything!
Powered by MailChimp
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
ABB – Electrical Installation Handbook PART I
Scope and objectives The scope of this electrical installation handbook is to provide the designer and user of electrical plants...
Basic Instruction XIC
This video demonstrates a unique but very important concept regarding how the XIC instruction should be understood or interpreted by...
Coordinated Power Systems Protection
Purpose This manual establishes the criteria for design, coordination, and construction of power systems for military projects. A secondary purpose...
Close
