Three Phase Power
Formulas
For a balanced star connected load with line voltage Vline and line current Iline:
Vstar = Vline / Ö3
Istar = Iline
Zstar = Vstar / Istar = Vline / Ö3Iline
Sstar = 3VstarIstar = Ö3VlineIline = Vline2 / Zstar = 3Iline2Zstar
For a balanced delta connected load with line voltage Vline and line current Iline:
Vdelta = Vline
Idelta = Iline / Ö3
Zdelta = Vdelta / Idelta = Ö3Vline / Iline
Sdelta = 3VdeltaIdelta = Ö3VlineIline = 3Vline2 / Zdelta = Iline2Zdelta
The apparent power S, active power P and reactive power Q are related by:
S2 = P2 + Q2
P = Scosf
Q = Ssinf
where cosf is the power factor and sinf is the reactive factor
Note that for equivalence between balanced star and delta connected loads:
Zdelta = 3Zstar
NOTATION
The symbol font is used for some notation and formulae. If the Greek symbols for alpha beta delta do not appear here [ a b d ] the symbol font needs to be installed for correct display of notation and formulae.
B
C
E
f
G
h
I
j
L
P
Q
susceptance
capacitance
voltage source
frequency
conductance
h-operator
current
j-operator
inductance
active power
reactive power
[siemens, S]
[farads, F]
[volts, V]
[hertz, Hz]
[siemens, S]
[1Ð120°]
[amps, A]
[1Ð90°]
[henrys, H]
[watts, W]
[VAreactive, VArs]
Q
R
S
t
V
W
X
Y
Z
f
w
quality factor
resistance
apparent power
time
voltage drop
energy
reactance
admittance
impedance
phase angle
angular frequency
[number]
[ohms, W]
[volt-amps, VA]
[seconds, s]
[volts, V]
[joules, J]
[ohms, W]
[siemens, S]
[ohms, W]
[degrees, °]
[rad/sec]
Don't miss anything!
Powered by MailChimp
  1. [...] : http://electrical-engineering-portal.com/resources/knowledge/electrical-formulas/three-phase-power ShareLike this:LikeBe the first to like this post. Categories: Rumus | Leave a [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Transformer Winding Temperature Thermometer
These devices are supposed to indicate hottest spot in the winding based on the manufacturers heat run tests. At best,...
Neutral earthing in an industrial HV network
Abstract HV electrical networks can be earthed in different ways. This document analyzes the constraints imposed by the different parameters...
PROFIBUS – Cabling and Assembly
Routing of PROFIBUS Cables Copper cable General plant or factory cabling can carry high voltages and currents. Running PROFIBUS cables...
Close
