Home / Technical Articles / 8 Examples Of Transformer Differential Protection Using SIPROTEC Numerical Relays
Estimated Study Time: 18 minutes
Transformer Protection
The following examples show the application of SIPROTEC numerical relays for transformer protection. The individual functions are designated, using ANSI codes (Standard C37.2 – Electrical Power System Device Function Numbers).
8 Examples Of Transformer Differential Protection Using SIPROTEC Numerical Relays (photo credit: Siemens)
The integrated supplementary functions in each relay may be applied advantageously. It must however be noted that back-up protection functions for redundancy must be provided in a separate hardware (a further relay).
Therefore, the overcurrent protection included in the differential protection 7UT6 can only be implemented as back-up protection for external faults in the connected system.
The back-up protection for the transformer itself must be provided by a separate overcurrent relay (e.g. 7SJ600). The Buchholz (gas pressure) protection providing fast short-circuit protection is provided together with the transformer.
Contents:
  1. Two-winding transformer protection
  2. Three-winding transformer protection
  3. Transformer protection with restricted earth-fault protection
  4. Transformer protection for 1-½ circuit breaker arrangements
  5. Auto-transformer protection
  6. Protection for a large transformer bank
  7. Protection of regulating transformers
  8. Protection of generator transformer units
