Home / Technical Articles / Meet the Real Heart of Power System Operations – The Transmission Control Center
Estimated Study Time: 22 minutes
Transmission Control Center Desks
The transmission control centre is the real heart of every utility’s power system operations. Typical transmission control centres have three main desks – the generation, transmission and scheduling desk.
Transmission Control Center - The Heart of System Operations
Let’s take look at three main transmission and other support desks we can see in almost every utility’s control room:
  1. Transmission Desk
  2. Generation Desk
  3. Scheduling Desk
  4. Other Support Desks
The transmission desk is basically responsible for overall security of the bulk power system. The transmission desk runs different kinds of analysis on the transmission system, constantly looking for weak spots and constantly asking “how can I get out of this?”
The system operator has several tools at his or her disposal to perform these analyses:
  1. SCADA
  2. State Estimator
  3. Power Flow
  4. Contingency Analysis Application
  5. Optimal Power Flow
  6. Security Enhancement
1.1 SCADA
This is the main application that is the eyes, ears, and arms for the operator. Through this application, sensors in the field send in data into the control center. Alarms get issued when data exceeds one or more limits that are set for them. SCADA also allows the operator to control devices in the field, such as open/close circuit breakers, change transformer taps, and so on.
It basically reports the data that it receives from the field in a raw form and converts it into engineering units based on the actual quantity that it is sensing. The data could be any of current (amps), voltages (kV), or power flow (megawatts (MW) or megavolt ampere reactive (MVAR)).
It could even be something like the status of a substation door (open/close).
The incoming data from SCADA has all kinds of variables—generator output MW, MWh, MVAR, and MVARH, power flow values through lines measured either in MW and MVAR or current values in amperes. Much of this data is sensed in the field, collected by devices called RTUs or IEDs, which then send the data to the control center through a dedicated set of communication lines.
SCADA has one main problem. It does not know if the data is accurate or not. It cannot also confirm whether the circuit breaker status is open or not, even if the data that comes in says so. These errors could happen due to the meter either reading wrong or just malfunctioning.
It could also happen if the meter parameters are adjusted in error, leading to inaccurate conversion from raw to engineering units. When this happens, the information is still reported as is, and this is where the state estimator comes in.
Good to know!Save 50% on all video courses with Enterprise plan.
