Any change in current in a coil (either a rise or a fall) causes a corresponding change of the magnetic flux around the coil. Because the current changes at its maximum rate when it is going through its zero value at 90° (point b on Figure 1) and 270° (point d), the flux change is also the greatest at those times.
Consequently, the self-induced EMF (electromagnetic field) in the coil is at its maximum (or minimum) value at these points, as shown in Figure 1.
Because the current is not changing at the point when it is going through its peak value at 0° (point a), 180° (point c), and 360° (point e), the flux change is zero at those times. Therefore, the selfinduced EMF in the coil is at its zero value at these points.
According to Lenz’s Law, the induced voltage always opposes the change in current. Referring to Figure 1, with the current at its maximum negative value (point a), the induced EMF is at a zero value and falling. Thus, when the current rises in a positive direction (point a to point c), the induced EMF is of opposite polarity to the applied voltage and opposes the rise in current.
With the current now at its maximum positive value (point c), the induced EMF is at a zero value and rising. As the current is falling toward its zero value at 180° (point c to point d), the induced EMF is of the same polarity as the current and tends to keep the current from falling. When the current reaches a zero value, the induced EMF is at its maximum positive value.
Later, when the current is increasing from zero to its maximum negative value at 360° (point d to point e), the induced voltage is of the opposite polarity as the current and tends to keep the current from increasing in the negative direction. Thus, the induced EMF can be seen to lag the current by 90°.
The value of the self-induced EMF varies as a sine wave and lags the current by 90°, as shown in Figure 1. The applied voltage must be equal and opposite to the self-induced EMF at all times; therefore, the current lags the applied voltage by 90° in a purely inductive circuit.
If the applied voltage (E) is represented by a vector rotating in a counterclockwise direction (Figure 1b), then the current can be expressed as a vector that is lagging the applied voltage by 90°. Diagrams of this type are referred to as phasor diagrams.
Example
A 0.4 H coil with negligible resistance is connected to a 115V, 60 Hz power source (see Figure 2). Find the inductive reactance of the coil and the current through the circuit. Draw a phasor diagram showing the phase relationship between current and applied voltage.
Solution
1. Inductive reactance of the coil
XL = 2 · π · f · L
XL = 2 · 3.14 · 60 · 0.4
XL = 150.7 Ohms
2. Current through the circuit
I = E / XL
I = 115 / 150.7
I = 0.76 amps
3. Draw a phasor diagram showing the phase relationship between current and applied voltage
Phasor diagram showing the current lagging voltage by 90° is drawn in Figure 2b.
Summary
Inductive Reactance Summary
- Opposition to the flow of alternating current caused by inductance is called Inductive Reactance (XL).
The formula for calculating XL is:
XL = 2 · π · f · L
. - Current (I) lags applied voltage (E) in a purely inductive circuit by 90° phase angle.
. - The phasor diagram shows the applied voltage (E) vector leading (above) the current (I) vector by the amount of the phase angle differential due to the relationship between voltage and current in an inductive circuit.
SOURCE: Handbook of electrical science volume 3 – Download it here[/fancy_box]
Nice explanation
If the induced voltage and the source voltage are 180° out of phase shouldn’t they cancel each other out.
But when I connect a CRO across the inductor, it showed the source voltage waveform. Im confused
good job
Please verify the unit for inductive reactance in your example. It must be in Ohms not W.
You’re right, thank you for noticing!!
