Home / Technical Articles / What Standards To Use For Transformer Oil Testing?
Complete analysis of a transformer’s oil
ASTM (American Society for Testing and Materials) has developed the standards for oil testing. The following tests we recommended for a complete analysis of a transformer’s oil:
ASTM standards for transformer oil testing and complete analysis of a transformer’s oil
Dielectric breakdown (ASTM D-877 & D-1816)
The dielectric breakdown is an indication of the oil’s ability to withstand electrical stress. The most commonly performed test is ASTM D-877, and because of this, it is more readily used as a benchmark value when comparing different results. The oil sample is placed in a test cup and an AC voltage is impressed on it. The electrodes are two discs, exactly 1 in. in diameter and placed 0.10 in. apart.
The voltage is raised at a constant rate, until an arc jumps through the oil between the two electrodes. The voltage at which the arc occurs is considered the dielectric strength of the oil.
Premium Membership Required
Log In »Purchase »
thirty three  ⁄  eleven  =
