Study specialized electrical engineering articles, papers & video courses in low/high voltage areas. Get 50% OFF on all courses at the EEP Academy with the Enterprise Plan.
Home / Technical Articles / 13 Basic expressions often used in electrical testing
Testing of electrical installations
This is the simple list of basic terms you can often hear when testing and measurements of electrical installation (in general) is being performed. While experienced electrical engineers will find this list short, I hope beginners will catch the essence and continue exploring this field of electrical engineering.
13 Basic expressions often used in electrical testing (photo credit: novuscompliance.co.uk)
Feel free to suggest me an expression (along with description) you think it should be listed, it will be my pleasure to add it to the list and to move away from number 13 :)
Ok, so here is the list:
  1. Active accessible conductive part
  2. Passive accessible conductive part
  3. Electric shock
  4. Earthing electrode
  5. Nominal voltage
  6. Fault voltage
  7. Contact voltage
  8. Limit Contact voltage
  9. Nominal load current
  10. Nominal installation current
  11. Fault current
  12. Leakage current
  13. Short-circuit current
  14. Electrical Insulation (UPDATE!)
  15. Harmonics levels (UPDATE!)
Active accessible conductive part is the conductive part of an electrical installation or appliance such as the housing, part of a housing etc. which can be touched by a human body. Such an accessible part is free of mains voltage except under fault conditions.
Switchboard contruction grounded
Switchboard contruction grounded (photo credit: ecsanyi)
Go back to List ↑
Passive accessible conductive part is an accessible conductive part, which is not a part of an electrical installation or appliance, like:
  • Heating system pipes,
  • Water pipes,
  • Metal parts of air condition system,
  • Metal parts of building framework
  • etc.
Equipotential bonding of metal pipes
Equipotential bonding of metal pipes (photo credit: diy.stackexchange.com)
Go back to List ↑
3. Electric shock
Electric shock is the pathophysic effect of an electric current flowing through a human or animal body. Very dangerous, have eyes on your back while testing.
It’s very important to know what to do if electric shock occurs.
What you need to know about electric shock
Electric shock – Emergency resuscitation procedures (photo credit: uksafetystore.com)
Download poster
Go back to List ↑
Earthing electrode is a conductive part, or a group of conductive parts, which are placed into earth and thus assure a good and permanent contact with ground.
Earthing electrode
Earthing electrode
Earthing electrode
Earthing electrode (photo credit: wikipedia.org)
Go back to List ↑
5. Nominal voltage
Nominal voltage (Un) is the voltage which electrical installations or components of electrical installations, such as appliances, loads etc. are rated at. Some installation characteristics also refer to nominal voltage (e.g. power).
Go back to List ↑
6. Fault voltage
Fault voltage (Uf) is the voltage that appears between the active accessible conductive parts and the passive ones or ideal ground in the case of a fault on appliances connected to the mains installation (connected appliance).
The figure below represents the Fault voltage (Uf) and division of the voltage into the Contact voltage (Uc) and voltage drop on floor/shoes resistance (Us).
Presentation of the voltages Uf, Uc and Us in case of a fault on an electric load
Figure 1 – Presentation of the voltages Uf, Uc and Us in case of a fault on an electric load
  • ZB – Impedance of human body
  • RS – Floor and shoes resistance
  • RE – Earth Resistance of active accessible conductive parts
  • If – Fault current
  • Uc – Contact voltage
  • Us – Voltage drop on floor/shoes resistance
  • Uf – Fault voltage
Uf = Uc + Us = If × RE
(floor material is placed to ideal ground)
Go back to List ↑
7. Contact voltage
Contact voltage (Uc) is the voltage to which a human body is exposed when touching an active accessible conductive part. The body is standing on the floor or is in contact with passive accessible conductive part.
Measuring: Contact voltage is measured between the earthing electrode and two measurement electrodes connected together and placed 1m away from tested earthing electrode.
Voltage apportion across the Earth Resistance - voltage funnel
Voltage apportion across the Earth Resistance – voltage funnel
  • Uo – Ground potential
  • Ust – Step voltage
  • RE – Earth resistance
Go back to List ↑
Limit Contact voltage (UL) is the maximum Contact voltage which may be continuously present under certain external conditions e.g. presence of water.
Go back to List ↑
Nominal load current (In) is the current that flows through the load under normal operating conditions and at nominal mains voltage.
Nameplate of HP printer (I guess) with nominal values of voltage and current
Go back to List ↑
Nominal installation current (In) is the current that the installation draws under normal operating conditions.
Go back to List ↑
11. Fault current
Fault current (If) is the current that flows to active accessible conductive parts and then to ground in case of a fault on a mains appliance.
Download spreadsheet //
Fault Current Calculation Spreadsheet
Go back to List ↑
12. Leakage current
Leakage current (IL) is the current that usually flows through isolation materials or capacitive elements to ground in normal conditions.
Learn more //
Go back to List ↑
Short-circuit current (Isc) is the current that flows in a short circuit between two points of different potential.
Short-circuit current diagram
Learn more //
Go back to List ↑
A non-conducting material that provides electric isolation between two or many electrically live parts at different voltages or at same voltages. It should have a high electrical high resistivity and high dielectric strength commensurate with requirement form Voltage to voltage.
The electrical insulating materials are in solid (rigid & flexible), liquid and gaseous forms.
Updated by Mr. K.K. Murty, Jabalpur, India.
Motor windings insulation
Motor windings insulation (photo credit: primeelectricmotor.com)
Go back to List ↑
15. Harmonics Levels
Devices causing harmonics are present in all industrial, commercial and residential installations. Harmonics are caused by non-linear loads. A load is said to be non-linear when the current it draws does not have the same wave form as the supply voltage.
Voltage and current waveforms of an induction motor
Updated by Mr. Noel Phillips, Mumbai.
Go back to List ↑
Reference // Guide To Measurements On Electrical Installations in Theory and Practice (Download guide)
9 Comments
  1. Mohammed Ghazy
    Aug 31, 2019
    Good afternoon
    Please Can you explain about loop impedance test and RCD test for Electrical installation in any apartments
    Best regards
  2. Syed Toqeer Alam
    May 20, 2019
    How to work a surge arrestor, on voltage dip or current
  3. akram ashmawy
    Jan 19, 2019
    power factor value
  4. Stephen Boorer
    Dec 01, 2016
    Hello
    I really like your Facebook feed, great stuff.
    On the list of electrical terms at the top, I believe Earth Fault Loop Impedence (FLI) should be there.
  5. Milanović Nikola
    Nov 22, 2015
    First picture “Evrotehna” panel ?
  6. Mike Walker
    Aug 27, 2015
    How about “Finger Safe” meaning to suitably guard energized parts from accidental contact.
  7. sontakke.s.v.
    Jul 31, 2015
    Dear Eng.Mr.Edward, GREETINGS.
    All your articles are very informative and useful for the personalities in field of elec.Engg.
    Pl keep it up n With respectful Regards,
    sontakke.
  8. JP Delgado
    Jul 27, 2015
    Hi there,
    I hope you’re doing great. I love all your articles since I work in the electrical wholesale business and as an Electrical Engineer I can be very updated and refreshed about the concepts that I don’t use everyday and I just learnt while I was studying. I would like to ask for your permission to use some of the information that you show in this portal and translate it to spanish and use it for our facebook page always refering hat the information is provided by your EEPortal. I will look forward to your answer!
    Regards,
    Juan Pablo Delgado
  9. Nestor Casilla
    Jul 27, 2015
    Looking to keep up with what’s new in Electrical Engineering. Currently working as a Protection and Control Engineer.
Leave a Reply to Milanović Nikola
29  +    =  thirty one
Protection testing
