Home / Technical Articles / 4 Types of DC Motors and Their Characteristics
DC Motor Characteristics
As you already know, there are two electrical elements of a DC motor, the field windings and the armature.The armature windings are made up of current carrying conductors that terminate at a commutator.
4 Types of DC Motors and Their Characteristics (on photo: Collector of 575kw DC motor; credit: Pedro Raposo)
DC voltage is applied to the armature windings through carbon brushes which ride on the commutator. In small DC motors, permanent magnets can be used for the stator. However, in large motors used in industrial applications the stator is an electromagnet.
When voltage is applied to stator windings an electromagnet with north and south poles is established. The resultant magnetic field is static (non-rotational).
For simplicity of explanation, the stator is represented by permanent magnets in the following illustration.
DC Motor Construction
The field of DC motors can be:
  1. Permanent magnet (Permanent magnet stator),
  2. Electromagnets connected in series (Wound stator),
  3. Shunt (Wound stator), or
  4. Compound (Wound stator).
Let’s see the basics of each type as well as their advantages and disadvantages.
1. Permanent Magnet Motors
The permanent magnet motor uses a magnet to supply field flux. Permanent magnet DC motors have excellent starting torque capability with good speed regulation. A disadvantage of permanent magnet DC motors is they are limited to the amount of load they can drive.These motors can be found on low horsepower applications.
Another disadvantage is that torque is usually limited to 150% of rated torque to prevent demagnetization of the permanent magnets.
Go back to Index ↑
2. Series Motors
Series DC motor
Series DC motor
In a series DC motor the field is connected in series with the armature.The field is wound with a few turns of large wire because it must carry the full armature current.
A characteristic of series motors is the motor develops a large amount of starting torque. However, speed varies widely between no load and full load. Series motors cannot be used where a constant speed is required under varying loads.
Additionally, the speed of a series motor with no load increases to the point where the motor can become damaged. Some load must always be connected to a series-connected motor.
Series-connected motors generally are not suitable for use on most variable speed drive applications.
Go back to Index ↑
3. Shunt Motors
DC Shunt Motor
DC Shunt Motor
In a shunt motor the field is connected in parallel (shunt) with the armature windings. The shunt-connected motor offers good speed regulation. The field winding can be separately excited or connected to the same source as the armature.
An advantage to a separately excited shunt field is the ability of a variable speed drive to provide independent control of the armature and field.
The shunt-connected motor offers simplified control for reversing. This is especially beneficial in regenerative drives.
Go back to Index ↑
4. Compound Motors
Compound DC motor
Compound DC motor
Compound motors have a field connected in series with the armature and a separately excited shunt field. The series field provides better starting torque and the shunt field provides better speed regulation.
However, the series field can cause control problems in variable speed drive applications and is generally not used in four quadrant drives.
Go back to Index ↑
DC Motor – Explained (VIDEO)
Reference: Basics of DC Drives – SIEMENS (Download)
26 Comments
  1. Abdulkadir Bello Nalizai
    Sep 24, 2022
    Fantastic explanation . Thanks Great Engr
    • Muhammad Nuhu Muhammad
      Jul 05, 2023
      Thanks so much
  2. Shubham Ramchandra Pal
    Oct 23, 2021
    very nice and simplified explanation
  3. Abdulwaris
    Nov 17, 2019
    How can I get pdfs document to have it for future studies and so many times I tried to download it but I couldn’t some of ur materials are really interested but I’m not able to download it if u help me it will be ur pleasure
  4. Bharath
    Oct 30, 2019
    Thanks a lot for giving a info
  5. Aya Saleh
    Jul 05, 2019
    That was very useful ♥️
  6. GAJANAND SAIN
    Jun 03, 2019
    THANKS
  7. sampath
    Jan 30, 2019
    extremely very interesting
  8. SUNIL PADMASHALI
    Aug 23, 2017
    Very useful information Thank you
  9. Ghazi Kazmi
    Jan 08, 2017
    nice job
  10. Cy
    Aug 19, 2016
    The Brushed DC motor variety has a type when one turns the shaft manually it free runs with no friction or resistance at all and then another type which feels like a mild step friction/resistance as though magnets inside causing some type of resistance when the shaft passes them? Which type are these and what is the difference.
  11. KAVAN
    Jul 27, 2016
    thanks that was very helpful because i needed to do a sience project and i wanted to do DC motors because i do RC racing and i use a DC motor in it.
  12. murugan .T
    Jun 26, 2016
    not bad.improve in your presentation .
  13. ARKA CHATTERJEE
    May 02, 2016
    can you tell me what is the approx ohmic range of starting resistance of a dc motor?
  14. Uday
    Nov 08, 2015
    Very useful information in simple words understandable to all….
    Thanks for the explaination
  15. u.k.sharma
    Oct 24, 2015
    thank u,it is useful but here is not about short shunt & long shunt dc motor.
  16. usman ghani
    Oct 21, 2015
    exellent informestion
  17. rob
    Oct 14, 2015
    Can you tell me if the actual resistance value of the rotor, field and poles is critical to the operation of a DC Series wound motor and if so how it can be determined
  18. m.shivakumar
    Aug 14, 2015
    excellent information sir thank u a lot plz tell me the basics of electrical engineering sir
  19. SADGUN VAMSHIDHAR REDDY KANDI
    May 02, 2015
    This is an excellent site helping me beyond my academic studies.
  20. Jose
    Jan 16, 2015
    Could you explain me about Ethernet , mod-bus, what it is?
  21. Jose
    Jan 16, 2015
    Excellent information.
    Do you have information about squirrel cage motor?
    • Brijmohan Paliwal
      Apr 09, 2015
      Squirrel cage motor is AC motor whose rotor is made of copper rods short circuited at both ends.EMF is induced by mutual induction method.
      AC voltage is applied to stator of the motor.in turns it produces rotating magnetic field and produces starting torque to rotate the rotor of motor.
  22. PETER
    Jan 10, 2015
    Thank you, very useful
  23. Марк
    Jan 09, 2015
    In the future, you can find points of contact
  24. bharath
    Jan 08, 2015
    Nice overview of DC machines.. Wanna know about synchronous machines and DC choppers
Leave a Reply to GAJANAND SAIN
thirty  −    =  twenty six
